Timing Cover Leaking Oil !!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trdoffroad1149, Apr 3, 2017.
  1. Apr 3, 2017 at 6:19 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Ford deemed the Pinto rear gas tank fires normal.
    Normal != Okay or acceptable
    It just means it's "normal" for Tacomas to sound like a howler monkey on the highway. In some ways it's more damning for Toyota to chalk this up as normal.
    That means it's common.
  2. Apr 3, 2017 at 6:22 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    only way you will prove it to Toyota corp is to have the rear examined by an expert a 3rd party and if the conclusion says its a defect then you have a case, but the facts are Toyota corp considers it normal till then
  3. Apr 3, 2017 at 6:25 PM
    TheCookieMonster
    North East
    my 22re has had noisey valves since I have owned it buts that's common with the engine, ive had them adjusted,tried different oil brands/weights, spark plugs. its just how it is.
    asuchemist likes this.
  4. Apr 3, 2017 at 6:38 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Im going to guess that the leak is on the passenger side right where the head meets the block
  5. Apr 4, 2017 at 6:08 AM
    Trdoffroad1149
    Trdoffroad1149 [OP] Well-Known Member
    Jacob
    Wilkesboro, NC
    2016 TRD Off-road
    275/70/17 BFG KO2 TRD Pro 4Runner wheels TRD Pro Grill
    Yep! That's exactly where it's coming from.
  6. Apr 4, 2017 at 6:14 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I worked at a Suzuki dealer 13 or so years ago. We did 4-6 timing cover reseals a week. Never had to pull an engine to do one.
  7. Apr 4, 2017 at 6:21 AM
    Trdoffroad1149
    Jacob
    Wilkesboro, NC
    2016 TRD Off-road
    I've never heard of having to do that either, but from what I've been told it's the only way to perform the job on these 3rd Gen trucks.
  8. Apr 4, 2017 at 6:22 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Not sure about third gen tacomas, but on the newer ford diesels I work on, to reseal the front cover, you're supposed to remove the transmission because the upper oil pan bolts to the front cover, and that can only come out the rear, after the transmission and flexplate have been removed. I can't think of a reason theyd have to pull the trans and engine, but I haven't worked on a third gen, or even second gen for that matter. Just my first gen.
    Sorry to hear about your issues and misfortune. Hope you enjoy the truck after it's fixed.
  9. Apr 4, 2017 at 6:25 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Thinking about doing the same thing. No problems with mine other than a mildew smell when you turn the fan on and the few fungus gnats that bounce around in your line of site on the inside of the windshield.
  10. Apr 4, 2017 at 6:30 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Did you change your cabin filter?
  11. Apr 4, 2017 at 6:31 AM
    CusterFan
    No, I was trying to hold off till the trees get through pollinating. But thinking about stopping in Walmart in the morning and picking one up.
    MoneyMan55[QUOTED] likes this.
  12. Apr 4, 2017 at 6:34 AM
    MoneyMan55
    Doug
    South Central PA
    Yeah cherry blossoms going to town here in Pa. Zyrtec stocks should be way up!
    CusterFan[QUOTED] likes this.
  13. Apr 4, 2017 at 6:43 AM
    CusterFan
    I park next to 2 big Sweet Gum trees and the pods are getting ready to release big clouds of yellow pollen. Red buds are in full bloom here in Illinois but I was never bothered by there pollen. Freaking Sweet Gum trees are just plain nasty but they do put out some serious shade.
    Hey I was looking under my hood yesterday, does the a/c condensation collect in a housing right under that cabin filter? I see where it runs through the firewall and it is about right in line with the cabin filter/glove box. May give that a couple blasts of Lysol before I put the new filter in.
  14. Apr 4, 2017 at 6:47 AM
    MoneyMan55
    Doug
    South Central PA
    Yes that is correct. On the firewall side, you should be able to see the short drain line about maybe three inches long. Good observation. 409 works good also.
  15. Apr 4, 2017 at 6:53 AM
    #35
    CusterFan
    I picked up a bottle of LA Awesome Orange Cleaner from Dollar tree that I like real well. Although I have used gallons of 409 in the past. Think I'll give the drain tube a couple quick blasts of canned air before I take the filter out just to make sure it is draining. Don't recall seeing the ground wet under my truck last summer. Thinking it may have a obstruction in the hose.
  16. Apr 4, 2017 at 6:56 AM
    #36
    MoneyMan55
    Doug
    South Central PA
    Sounds like a good project. Have fun.
  17. Apr 4, 2017 at 7:18 AM
    #37
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    You're probably still thinking Toyota makes the best and most reliable vehicles available because your mom had a bullet proof 2003 Camry or something.
    Sadly this isnt the case anymore with all Toyota cars. Some are worse than others and the 2016 Tacoma happens to have "much worse than average" reliability.
    Just get it repaired but I get what you mean. You'll be driving puckered from now on.
  18. Apr 4, 2017 at 7:19 AM
    #38
    mlcc
    Oregon
    2grs and 1grs have always had that problem from the get go, the tricky part is that you have to remove the upper oil pan to remove the timing cover.
  19. Apr 4, 2017 at 7:27 AM
    #39
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Honestly, mine is a pretty good truck. This forum will make you paranoid if you aren't careful.
    Honestly, if you are thinking about re-gearing, this might be a good idea.
  20. Apr 4, 2017 at 7:30 AM
    #40
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Now you know why the 2016 was traded in.
    Wonder what other problems it had, persuading the previous owner to trade it in.
