Timing cover oil leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loudog504, Jul 17, 2019.
  1. Jul 17, 2019 at 6:17 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Look over on the passenger side of the engine, leaking oil will be dripping around the PS Pump.
    doublethebass[QUOTED] likes this.
  2. Jul 17, 2019 at 6:19 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Will do
    shakerhood[QUOTED] likes this.
  3. Jul 17, 2019 at 6:24 PM
    TacoGreg
    TacoGreg Well-Known Member
    Tomball TX
    2017 Tacoma TRD Sport 4x4
    Damn. I bet you will not leave with everything you came in with. Like various caps, cable ties, push pins, maybe even a bolt or two.
    2016Tacoman likes this.
  4. Jul 17, 2019 at 6:27 PM
    SgtPuddin
    SgtPuddin Well-Known Member
    Mississippi
    2018 Tacoma TRD Off-Road DCLB
    KO2 Ray10 5100’s 884’s Rx350 Retro Headlights
    I would have just done this.....
  5. Jul 17, 2019 at 7:57 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    As a guy who cleans his oil drain pan with brake cleaner, Holy fuck that gives me anxiety
    shakerhood likes this.
  6. Jul 18, 2019 at 2:00 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Looking at those pics make a great point for a timing belt vs a chain. :crapstorm::boink:
    This problem has been ongoing since 2007 with the 2GR and they still throw the FIPG in there. Looks like it's the EXACT same seep point since 2007. Timing belt is a pain in the wallet if you do it every 90k miles, $750 at the dealer with water pump.
  7. Jul 18, 2019 at 2:04 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    What's FIPG? So you're for the chain or against it?
  8. Jul 18, 2019 at 2:09 PM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    form in place gasket, used lots of places on vehicles by many manufacturers. A very heavy duty RTV
    monkeyface and ryan760 like this.
  9. Jul 18, 2019 at 2:16 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Ahh. That's right. Seal packing
  10. Jul 18, 2019 at 2:30 PM
    monkeyface
    Colorado
    Liquid gasket, as opposed to something like a head gasket.
    I'm usually in favor of a chain, but this 3.5l 2GR appears to have some continual problems. It's not the chain's fault though, appears it's just poor gasketing.
    Thing is, a belt replacement is cheap, if you have a shitty chain design it's $2600 out of warranty.
    I didn't have a problem with the 22re chain, although the tensioner was going out at about 170k miles, no leaks though. The 2.7l chain in the '97 went 110k miles, no leaks. The 4.0l I only had it 27k miles.
  11. Jul 18, 2019 at 2:39 PM
    monkeyface
    Colorado
    Apparently whatever Toyota is using isn't all that great. A quick Google search shows the same leak point since 2007.
  12. Jul 18, 2019 at 5:47 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Name one other truck, any truck, that doesn't have issues of its own. Let he who is without sin...
  13. Mar 1, 2023 at 5:37 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    No room in the engine bay dude
  14. Mar 1, 2023 at 5:37 PM
    LeakyAC
    2.7 mochine nevar brek
  15. Mar 1, 2023 at 5:47 PM
    #35
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    3 years late to the party sir.
    tonykarter likes this.
  16. Mar 1, 2023 at 5:50 PM
    #36
    LeakyAC
    Nobody ever sends me the party invites
  17. Mar 1, 2023 at 5:53 PM
    #37
    Loudog504
    Loudog504 [OP] Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Skydvrr likes this.
