Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Mar 22, 2017 at 12:01 PM
    #2101
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    OP, very impressive sir...i am looking to sell my 08 TRD sport with 6' bed...does anyone know if the dome and map lights are the same as the 05-11? And how about the configuration of the bed? Want to take my bed mat and led lights.
    Tnx for any info
  2. Mar 22, 2017 at 12:40 PM
    #2102
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    As long as you are going to the same bed length the mat will work.
    brny67[QUOTED] likes this.
  3. Mar 22, 2017 at 2:25 PM
    #2103
    Shermyota30
    Shermyota30 Well-Known Member
    Bay Area
    17 sport 2wd doublecab
    Yes, I'm alway up to date with Apple's iOS updates. Everything works except for the message and reading it out. I'm thinking the Eutune needs to be updated to the latest software.
    Spearfish76 likes this.
  4. Mar 22, 2017 at 2:43 PM
    #2104
    Shermyota30
    Bay Area
    That is exactly how my set up acts up. It only shows ignore. It will ask if you want to set up message again hit yes and it does nothing but if you toggle " show notification" then say yes to set up message it works. Until the next morning when you start your truck up again.
  5. Mar 22, 2017 at 2:45 PM
    #2105
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    yep. i bought a shortbed mat from a 2014 member and it's perfect.
    shakerhood[QUOTED] likes this.
  6. Mar 22, 2017 at 4:45 PM
    #2106
    th365thli
    th365thli Well-Known Member
    Jerry
    Bay Area
    2019 Ram 1500 Big Horn Quad Cab
    A tangent,
    So when I drive at highway speeds the ride gets....bouncy. I have the TRD 4x4 offroad DC longbed. Has anyone else experienced this? Or do I just need to break in the truck
  7. Mar 22, 2017 at 4:59 PM
    #2107
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    all trucks do this with longer beds.. throw some sand bags in the back or go slower or faster than the speed it does it's bouncy thing.
    th365thli[QUOTED] and Cuffs like this.
  8. Mar 22, 2017 at 5:27 PM
    #2108
    th365thli
    Jerry
    Bay Area
    Ahh okay thanks. This is my first truck so I'm a raw noob. Thankfully the bounce doesn't bother me at all
    venezian[QUOTED] likes this.
  9. Mar 25, 2017 at 10:15 AM
    #2109
    Froggyhill
    Froggyhill Chief installation coordinator
    Nelson
    CNY
    2017 Tacoma TRDOR DCSB-Inferno red
    Light covering of salt from upstate New York roads OEM Predator running boards,Gator trifold tonneau
    On my 2017 DCSBOR in settings on the entune head unit, there is a line for daytime running lights. It a check / no check box. Not sure what it's for? I don't have automatic lights except auto turn off. Any ideas to it's function?
  10. Mar 28, 2017 at 4:40 AM
    #2110
    jmdwifi
    jmdwifi My Inferno
    Fredericksburg, Virginia
    See profile
    I had to pop off my overhead cluster today. Headliner leaking (another story) I noticed the map lights twist out. Its only four clips holding the whole thing pops out easily. I have banana fingers so changing my map lights was a pain in the ass. popping this off will make it easy. The map lights are circled in red and the clips in blue. It just pulls off.
    Boghog1 and boynoyce like this.
  11. Mar 28, 2017 at 3:45 PM
    #2111
    007TRUCK
    007TRUCK Well-Known Member
    Whats the weight of the Offroad wheel?
  12. Mar 29, 2017 at 7:13 AM
    #2112
    Taco'bout It
    Taco'bout It New Member
    Adam
    VA
    2017 Tacoma TRD Off Road 4x4
    To start the truck without having your foot on the brake (useful for when a rider goes to the truck before you do and is sitting in the passenger seat) push the PTS button once and release, then push the PTS button and hold it till the truck starts (Approximately 10-13 seconds). This process was tested on a 2017 Tacoma TRD Off Road with an Automatic Transmission and still requires the smart key to be in the vehicle in order to start.
    JenR8r88 and Mike O like this.
  13. Mar 29, 2017 at 8:53 AM
    #2113
    jmdwifi
    jmdwifi My Inferno
    See profile
    And when you get it working, at some point for no reason it will stop working. I found if I remove and add it again, it works.
  14. Mar 29, 2017 at 11:12 AM
    #2114
    AAChaoshand
    AAChaoshand [OP] Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Added to the list
    Taco'bout It[QUOTED] and Age315 like this.
  15. Mar 29, 2017 at 11:11 PM
    #2115
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Confirmed in 2016 Tacoma TRDOR auto Trans.
    Taco'bout It[QUOTED] likes this.
  16. Mar 30, 2017 at 4:59 PM
    #2116
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Check your tire air pressure - once they get heated up and around 35 psi I notice the bouncing... I'm in a Limited...
    shakerhood likes this.
  17. Apr 1, 2017 at 6:10 PM
    #2117
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Thank you sir, I had been searching for this information.
  18. Apr 2, 2017 at 7:25 AM
    #2118
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    In the Double Cab. Behind the rear seats, the cubby; fits 1 gal jugs perfectly.
    Found out when I had to go to the store to get milk and tea from Publix.
  19. Apr 2, 2017 at 5:45 PM
    #2119
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    Sounds like a good way to forget about a gallon of milk
  20. Apr 2, 2017 at 5:57 PM
    #2120
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    I was thinking 'why? I'll never remember it's there!'
    Orlandoech likes this.
