Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Jul 6, 2018 at 9:02 AM
    #2541
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    @AAChaoshand ,
    Something I would like to add to list, at least for a 2018 which I discovered on my new 2018 Sport.
    If you already have Cruise Control engaged, holding the Cruise Control lever up or down and releasing it when the desired indicated speed is reached, your Taco will start working towards the new speed, even if your speed is actively being reduced by Dynamic Cruise Control ( DCC ). You can see the speed you are changing to by watching the center Set Speed Indicator which is located in the top-right center section of the driver's cluster. I have mine set the compass which also provides the speed limit indicator in the bottom-right.
  2. Jul 6, 2018 at 3:02 PM
    #2542
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    and i was thinking traded for 17 tacoma with a 2.7 after i read this i will keep my 12
    mtip likes this.
  3. Jul 9, 2018 at 1:01 PM
    #2543
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    I think it may only be a 18 and newer thing because I could not get my 17 to do this.
  4. Jul 9, 2018 at 2:14 PM
    #2544
    Norsemanvike
    Escondido, CA
    That could very well be true.
  5. Jul 9, 2018 at 3:15 PM
    #2545
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    My 2nd gen would do this I think (except for overriding the radar of course). My 18 does it too.
    Norsemanvike likes this.
  6. Jul 9, 2018 at 7:09 PM
    #2546
    Lake Effect= 4 x 4
    Lake Effect= 4 x 4 Barcelona Beagle
    OHIO
    2018 Tacoma SR Barcelona Red 2.7 4cyl 4 x 4
    Great tips! Keep 'em coming.
  7. Jul 15, 2018 at 6:11 AM
    #2547
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    You are correct about placing the FOB up to the push button switch for starting issues. Although it is not a battery issue. The battery only powers the lock/unlock FOB features. The issue with the no start is related to the FOB itself or a module issue. There is a resistor in the FOB that the PCM and/or other modules confirm to allow the vehicle to start. Other FOBs or remotes on the same key chain can sometimes interfere with the signal.
  8. Jul 15, 2018 at 8:06 AM
    #2548
    Lake Effect= 4 x 4
    OHIO
    Dropping/removing your spare tire on a New Tacoma!!! El Simpolo, eh?
    I am rustproofing the undercarriage and have got to drop the spare tire on my 2018 SR to squirt Fluid Film up yonder. Looked in the Owner's Manual (page 599 of 696 pages)--yeah--plunge in and turn the "hooked" crank thing "lefty-loosey" in the hole under the bed.
    Did same. WON'T BUDGE an inch. I'm 250 lbs, 6' 1" and worked on farms, timbered, and in steel mills during my 75 years on God's green earth, so I have a good grip on things. BUT--I'm smart enough to know--if stuff don't budge, back off and take 'er easy or things go BUSTED pretty durn quick.
    So I call TOYOTA.usa and my Dealership's Service Mgr.--which both chime in: "Gee, we've never been asked that question before. Mebbe watch a few You Tubes and get some ideas..." :annoyed:
    Sooo, I watch some You Tubes on "Dropping a Tacoma Spare Tire." Yep--did same and here's the deal from Georgia Tacoma Dealer:
    "At Factory--Toyota places a stout back polymer "collar" on the spare tire winch spool/cone down there, which needs a REAL BIG MANLY CCW turn to crack it off underneath there and allow the rod to turn CCW. It keeps stuff in order until you, the new owner get the unit."
    OK! Heave Ho! "Pop! goes the plastic collar" and the tire, she is lowering. at least it's a full-sized! Spraying that Fluid Film up there likes there's no tomorrow!
    Gee, whodathunk? I've been changing tires for 55 years, and this one really had me stumped. Senior moment?
    RJS59, Raker, Humble Soul and 2 others like this.
  9. Jul 15, 2018 at 9:39 AM
    #2549
    Norsemanvike
    Escondido, CA
    Good to know since I still need to drop mine and sure I know how it all works.
  10. Jul 15, 2018 at 10:09 AM
    #2550
    Lake Effect= 4 x 4
    OHIO
    Another "tip" I learned from my Honda 4 x 4 CRV 4 banger: about every 4th or 5th gas fill up, use the middle grade octane gas grade at the pumps, 90 oct or better. Even just putting in like 5 gallons helps. At least with the Honda 4 cyl. it somehow "boosts" mileage! I just hit 35 mpg with this trick in the CRV and hope to employ it on my new 2018 Tacoma 4 cyl.
    BTW, driving home 80+ miles from the Dealership with my new 2018 SR, I logged on 30 mpg AND that was going up some pretty hellacious hills (yes, Ohio does have some!) AND with my A/C going full bore in 98*F heat. Not bad for the first 90 miles--she sipped less than 3 gallons! AWE-SUM. My F-150 and Silverado--no can do--evah!
    SWEET!
    iltdi and pinochle like this.
  11. Jul 15, 2018 at 7:50 PM
    #2551
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    That's not really how octane works, but if it works for you, I guess do it.
  12. Jul 15, 2018 at 7:59 PM
    #2552
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Gas company’s hate him!
  13. Jul 15, 2018 at 8:04 PM
    #2553
    drwx
    M'boro, TN
    Wildcard, bitches!
  14. Jul 16, 2018 at 4:54 AM
    #2554
    Taco Pusher
    Taco Pusher Well-Known Member
    Brian
    2016 Red TRD off road
    None yet
    Can the windows be rolled down from the key fob?
  15. Jul 16, 2018 at 5:32 AM
    #2555
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    I so wish, but no.
  16. Jul 16, 2018 at 8:21 AM
    #2556
    Cubswin
    Cubswin Member
    With push button start, pressing the ignition switch twice without the brake engage will allow for power window/back glass/sunroof control...
  17. Jul 16, 2018 at 8:24 AM
    #2557
    Taco Pusher
    Brian
    None yet
    From the key fob, so the truck can cool off before I open the door to get in
  18. Jul 16, 2018 at 9:20 AM
    #2558
    drwx
    M'boro, TN
    honda ridgeline does that.....specifically, every honda i've ever had has done that.
  19. Jul 16, 2018 at 9:23 AM
    #2559
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    Well, that's good to know. Thanks!
  20. Jul 16, 2018 at 2:29 PM
    #2560
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    All you're doing here is turning on Accessory Mode.
