Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Sep 26, 2018 at 4:57 AM
    #2661
    Fiatbreath
    Fiatbreath Well-Known Member
    Patrick
    2016 Toyota Tacoma TRD sport
    265/70/ tires hankook
    I have a sport. I leave the lights on all the time, they shut off when I lock vehicle. They are basically auto lights. It does not say auto on the light arm, just says lights.
    jmaxwell2424 likes this.
  2. Sep 27, 2018 at 9:57 AM
    #2662
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    My 2018 Off road manual with tech only has auto brights.
  3. Sep 27, 2018 at 9:59 AM
    #2663
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I discovered when you walk up the truck with the key in your pocket, the interior lights come on. I thought I left the interior lights on. Cool feature.
  4. Sep 27, 2018 at 12:00 PM
    #2664
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    all of the trucks have auto-off lights and you can set the time they stay on after the vehicle is turned off. the feature being referred to in the previous few posts is auto-on lights... that is, lights that turn on when it gets dark outside. you can leave yours on all the time right now, but that's what they are.. on all the time even when it's sunny outside. true auto-on headlights run the DRLs when it's bright outside and switch to the headlights when it gets dark.
    that's not the feature being referred to as auto-headlights. auto-bright lights is part of the safety sense package and all 18s have that, regardless of trim level.
    kmlande23 and eddy out like this.
  5. Sep 28, 2018 at 12:42 PM
    #2665
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    I don't think mine can turn on interior lights with the headlight switch.
  6. Sep 28, 2018 at 12:48 PM
    #2666
    Raistlen0
    PA
    Is there a certain setting for this because I do not think mine does it.
  7. Sep 28, 2018 at 12:55 PM
    #2667
    toyotatacomaTRD
    I didn't adjust anything. But I'm guessing it's inside entune.
  8. Sep 28, 2018 at 1:21 PM
    #2668
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I'm not sure if there is a setting or if it comes with premium package. Mine does it and I have my puddle lamps wired into this. Only works if doors are locked and you walk up to it. For some reason if truck sits for more than a week it also doesn't work but after that its works again.
  9. Oct 2, 2018 at 7:01 AM
    #2669
    Pilvr83
    Pilvr83 Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    I am having trouble with my auto headlights. I set the time to each of the three options: 0 seconds/60 seconds/90 seconds "Time elapsed before headlights automatically turn off after doors are closed."
    My lights do not turn off with any setting above. I have to manually turn the auto lights off. The bad part on turning the lights off is the Daylight Running Lights do not automatically come back on. So if I drive to work at night and turn my lights off, when I leave in the morning I have to remember to turn the DRL's back on.
    sort of a pain with my memory!
    Is there maybe something I am doing wrong?
    What exactly does the 0 seconds mean to you? I thought setting to that would automatically turn the lights off when I turn off the engine and open/close a door.
    TexasWhiteIce likes this.
  10. Oct 2, 2018 at 7:30 AM
    #2670
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    I was hesitant at first to do this because I have no rattlecan skills. Cleaned it up real good with warm soap and water, used a scotch pad to score it a little. Used rustoleum high heat flat black, no undercoating. Big piece of cardboard to block overspray, blue painters tape on pipe to give a clean edge. Turned out perfectly and has been holding up very well.
    Cuffs, FlipDiver and beers@1600 like this.
  11. Oct 2, 2018 at 8:00 AM
    #2671
    Blazingbluesport
    The OC!
    Little dirty from overlanding trip. Yes like the look. Better than chrome for sure
    tAcomaPueblo and SilverII like this.
  12. Oct 3, 2018 at 3:12 PM
    #2672
    rmcabee
    rmcabee Well-Known Member
    Fernandina Beach, FL
    16 Tacoma TRD 4x4 Off Road :: Silver Sky Metallic
    Just upgraded to 285/70/17 tires and there is an obvious discrepancy between speedometer and actual speed (especially at higher speeds). Is there a way to recalibrate the SD?
  13. Oct 6, 2018 at 5:12 PM
    #2673
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I dunno if you can alter the speedo but you can use this to find the difference on a few speeds
    https://www.tacomaworld.com/tirecalc
    rmcabee[QUOTED] likes this.
  14. Oct 14, 2018 at 12:50 PM
    #2674
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '19 SSM Limited, '09 DCSB MGM OR
  15. Oct 16, 2018 at 11:18 AM
    #2675
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
  16. Oct 16, 2018 at 1:25 PM
    #2676
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Just learned something I never knew about my Tacoma...lane change, just a quick flick, let go and it continues for 3 cycles; no need to hold the stalk down when changing lanes.
    Boyitz and toyotatacomaTRD like this.
  17. Oct 16, 2018 at 1:33 PM
    #2677
    mlr69
    South Carolina
    Yep, that's #28 in the original post, waaaaay back on page one. By the way, that value can be changed from 3 to 5 or 7 (in case 3 blinks isn't enough), I had mine changed to 5.
  18. Oct 16, 2018 at 1:37 PM
    #2678
    Odi412
    Odi412 Well-Known Member
    PIttsburgh
    20 pro
    :smack:
  19. Oct 16, 2018 at 8:39 PM
    #2679
    greg8765
    greg8765 Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    that is bad ass!
  20. Oct 17, 2018 at 9:21 AM
    #2680
    The Fuzz
    The Fuzz Member
    Stephen
    2018 White TRD OR 4x4
    Super-helpful post for a fellow newcomer.
    Odd question, as this is my first truck with push-button and keyless start, if one were to exit the car in park and NOT shut the engine off, does the engine automatically turn off once the keyfob is a certain distance away from the vehicle?
    burntcremebrulee likes this.
