Tips and Tricks on the 3rd Gen Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AAChaoshand, Jan 22, 2016.
  1. Jan 26, 2020 at 4:28 PM
    #3081
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    Which wire would get the fuse?
  2. Jan 26, 2020 at 4:34 PM
    #3082
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Whatever one is bringing power into what you're doing. (Assuming you're DIY.)
    That isolates what you are doing from the rest of the truck. A great rule to go by is fuse it at 125% of normal amperage. And calculate your amperage draw using like 11.5 volts as nominal. Higher voltage will draw less power so it's an extra window of safety. Itll usually be 12.6v off and 14.7 running up to who knows what these trucks can push on demand, 15.5? I actually don't know how the charging system is controlled but I expect it charges at a high voltage to refill and tapers down depending on electrical load to save fuel. If GM did it in 2006, I expect Toyota does it now.
  3. Jan 26, 2020 at 5:12 PM
    #3083
    ORtoCOTaco
    Colorado
    Thanks for the reply. I'll look into the wiring a bit more to determine which one gets the fuse. It won't be happening for at least 2-3 weeks so I'll have some time to get everything in order.
  4. Jan 26, 2020 at 7:32 PM
    #3084
    jsh139
    jsh139 Member
    2019 Black TRD Pro
    I’ve had a few cars that did this (as well as be able to roll up the windows with the key fob). I actually tried it the first day I bought my truck. It doesn’t have that feature. And I looked through the options in Carista, and it’s not there either. So, no way to do it to my knowledge :(
    Norsemanvike[QUOTED] likes this.
  5. Jan 26, 2020 at 8:31 PM
    #3085
    Doobfucious
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Someone makes a piggyback module for it, damned if I can remember who though.
    jsh139[QUOTED] likes this.
  6. Jan 28, 2020 at 1:44 PM
    #3086
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    How?
  7. Jan 28, 2020 at 1:48 PM
    #3087
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    Mine has the choice for it on the handle. DRL, then park lights, then turn on the fog lights.
  8. Jan 28, 2020 at 1:49 PM
    #3088
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Ok, I'll bite. Turn your parking lights on, then turn your fog lights on.
  9. Jan 28, 2020 at 1:57 PM
    #3089
    imjustabill1970
    bill
    clarksville, tn
    That's pretty simple, but the fog lights do not come on in my truck when the DRLs are on so I never really thought of it having the parking lights on instead of the DRLs. I have to have my headlights turned on.
    mlr69[QUOTED] likes this.
  10. Jan 28, 2020 at 2:08 PM
    #3090
    tomwilson74
    Tom
    West Virginia
    The park lights have to be on before the fog lights come on in my truck.
  11. Jan 28, 2020 at 3:53 PM
    #3091
    imjustabill1970
    bill
    clarksville, tn
    Okay...yeah this is right. Sorry for the confusion.
    Is there a way to to always on fog lights? To have them on WITH the DRLs and not at least the parking lights?
  12. Jan 29, 2020 at 8:03 AM
    #3092
    mlr69
    South Carolina
  13. Feb 20, 2020 at 4:35 PM
    #3093
    Toyo901
    Toyo901 Well-Known Member
    Shaheen
    West Tennessee
    2019 White Tacoma TRD ORLB
    I just learned today that if your listening through Bluetooth you can skip having to go through 5 popups to get to the playlist you’re listening to. If you’re at the audio menu and tap the album artwork it will go straight to the current playlist.
    See photos below:
    C7398837-DC13-4F5E-8895-9C3906D5D0DA.jpg 9525A6DF-D474-4DE3-BEE0-10957F24CEBE.jpg
  14. Feb 20, 2020 at 5:07 PM
    #3094
    toottootbeepbeep
    toottootbeepbeep Well-Known Member
    2019 MGM DCLB TRD SPORT~
    hmm doesn't seem to work on mine. i'm wondering if it's because you're running the JBL system? i dont know if the interface runs any different on non-jbl. also, are you running music from your phone's music player? i tried doing it while running spotify and it didn't work. i don't have any music loaded into my phone so i couldn't test that out.
  15. Feb 20, 2020 at 5:49 PM
    #3095
    Toyo901
    Shaheen
    West Tennessee
    Spotify & Pandora are no-go, unfortunately. I should have included that. Only Itunes/ apple music worked.
    tallen316 likes this.
  16. Feb 21, 2020 at 5:07 AM
    #3096
    canbefound
    canbefound New Member
    2019 Off Road Pro
    This is an awesome list of things for a first-time owner to know. Thanks for the post!
    Cuffs and Norsemanvike like this.
  17. Feb 21, 2020 at 8:10 AM
    #3097
    FlywtrJoe
    FlywtrJoe A Secular Humanist Tacoma Owner
    Joe
    San Luis Obispo, Ca
    2018 TRD Pro Tacoma
    That’s the fun of this website. If you haven’t already done so, you might want to take a peak at the “What have you done to you’re 3rd gen Tacoma today,” thread. A lot of good info there
    Norsemanvike likes this.
  18. Feb 22, 2020 at 12:31 PM
    #3098
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I just came across this thread a couple of days ago. This item in particular interests me, but I haven't got it to work in my 2017 Limited (Pushbutton Start and AT). Are there any "tricks" involved in getting this to work?? :confused:
    I'm just trying to open the driver door, lean in (keys in pocket or on the seat) and start the truck.
  19. Feb 22, 2020 at 12:48 PM
    #3099
    mlr69
    South Carolina
    I read this a long time ago but never tried, until now.... and it just worked for me (2018 TRD Sport). I thought maybe your problem would be the door being open, but I tried with the drivers door open and closed and it worked both ways.
    Just confirming - you did have the fob in the cab, yes? And pushed the start button once, released, then held it down for about 15 seconds, yes?
  20. Feb 22, 2020 at 1:06 PM
    #3100
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I tried first with the key in my pocket, leaning in to the truck. Didn't work. Then I tried with the key laying on the driver seat. Still nothing.
    On one or two tries it went into ACC mode, which I think is normal for two presses?
    I may not have waited a full 15sec after the second button press. How long did you wait between presses?
    I did notice the "Check Charging System" warning appear in the column display.
    EDIT: Ok... Operator Error. I just didn't wait long enough. I would say it takes a full 15 seconds. Thanks for your help. :)
