Tips removing seized bed bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coffeeholic, Sep 20, 2019.
  1. Sep 22, 2019 at 10:19 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    Looks like you already got it but Kano Kroil is the best thing I have ever used.
    https://www.amazon.com/Kano-Kroil-P...ocphy=9061155&hvtargid=pla-548961577674&psc=1
    I understand about the leaking gas if it was not for that I would go with heat.
    It took a while before I gave into it but now I am sold. I heat the bolt or nut just to change collor, let it cool just e little then I can ratchet them right out. The expansion and heat breaks the rust bond. I have been able to get parts loose the Mechanic said could not be done.
    I also keep a fire extinguisher, and water hose on quick stand by.
    Fireball 00 and Wsidr1 like this.
  2. Sep 23, 2019 at 1:45 AM
    Coffeeholic
    Coffeeholic [OP] Well-Known Member
    2005 Tacoma TRD
    Looks awesome. I also recently read a scientific analysis that showed a 50/50 mix of acetone and automatic transmission fluid is one of the best concoctions of penetrating fluid
    sandsloth likes this.
  3. Sep 23, 2019 at 3:19 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Kroil or 50/50 acetone and trans fluid are my go-to remedies. Both are better than PB Blaster. Then, low pressure air impact and let it thud slowly on them in reverse, then a quick hit forward on some, then back into reverse.
    If that fails, torch time if it can be used safely.
  4. Sep 23, 2019 at 4:22 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Mine is too much for lug nuts and it is a 650. How much PSI? I am running 150 and it is rediculous.
    1997TacomaSR5 likes this.
  5. Sep 23, 2019 at 5:48 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    one trick I have for rust seized bolts and nuts is to tap them with a hammer, as it will break some of the rust in the threads. Heat sometimes work too
    But sometimes rust is stubborn and there's nothing to do other than drill and tap :(
  6. Jun 26, 2023 at 9:48 AM
    Chadley22
    Chadley22 Well-Known Member
    Chad
    Tacoma
    I'm working on a bed swap and the same thing happened to 2 of the bolts on my truck. The welded nuts are spinning inside the crossmember.
    How should I proceed with removal?
  7. Jun 26, 2023 at 2:29 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    living herein Pa I tried once for about 8 hours .
    Now I just use the torch and don`t mess around
    Chadley22[QUOTED] likes this.
  8. Jun 26, 2023 at 3:20 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    ATF with acetone works better than kroil or PB blaster, have used all three. Never heard of it till I joined this site. I mix a dab in a cup as needed and use a small paintbrush to apply. So far, hasn't failed from engine block bolts to bush hog blade bolts.
    Wsidr1[QUOTED] and Chadley22 like this.
