Tips wanted for getting un stuck.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by suomiM31, Nov 5, 2022.
  1. Nov 5, 2022 at 1:23 PM
    fandrews03
    fandrews03 Member
    Frank
    2021 Tacoma Off Road Short Bed
    Smartcap
    The new iPhone have limited satellite communications afaik. Don't have to get a Garmin any more
  2. Nov 5, 2022 at 1:27 PM
    Tacoma’20
    Tacoma’20 Well-Known Member
    Wincent
    Southern California
    2020 Silver Sky Metallic TRD O.R. 2wd
    Whoops, I didn't realize it's a manual. So no Crawl Control or MTS . . . but you do still have the rear locker and also A-Trac
  3. Nov 5, 2022 at 4:02 PM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
    suomiM31[OP] likes this.
  4. Nov 5, 2022 at 4:03 PM
    Bishop84
    Bishop84 Well-Known Member
    My biggest tip that was yelled at me.
    "STRAIGHTEN YOUR DAMN WHEELS"
    Wheels turned even 5 degrees adds to resistance. Keep em straight.
  5. Nov 5, 2022 at 4:16 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    See post #10
  6. Nov 5, 2022 at 4:19 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Turn traction control fully off (long press on the switch) traction control is for on road only will hinder you offroad.
    Get a winch if you are gonna be out there alone.
  7. Nov 5, 2022 at 4:22 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    See post #13
    Also post #1 in regards to traction control.
  8. Nov 5, 2022 at 4:24 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    First, do a quick edit on your post if you can.
    Second, can you put a cattle guard in over the ditch? Or something similar to bridge the gap?
    Somebody suggested hitting the ditch at a higher speed. I suggest you ignore that advice unless you know where the fine line is between success and expensive repairs.
    Benny blanco likes this.
  9. Nov 5, 2022 at 4:29 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I suggest getting stuck in a friendlier place to learn what your truck is capable of. Then avoid situations that your truck isn’t capable of handling, if possible.
  10. Nov 5, 2022 at 4:30 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Seems pretty capable seeing as how op made it safely to a keyboard and is now asking.
  11. Nov 5, 2022 at 4:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The rear locker. And you should be aired down to at least the low 20s in 10 inches of snow
  12. Nov 5, 2022 at 4:50 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Melting snow and mud. Tire chains make a huge difference.
    Mud Tires? TIRE CHAINS!!! - YouTube
    It's hard to say without being there, but often low range is a handicap. Someone else suggested hitting the bad spot with more speed. Once again impossible to say without seeing the spot. But keeping momentum is huge. And wheel speed is important to sling mud from tire tread. Even the most aggressive tires will fill up with mud and be as slick as a peeled onion unless they are turning fast enough to sling the mud out.
    There is a time to use finesse and work your way out which appears to be the method you used. And it worked for you. There are other times when it is best to muscle your way through. Experience will help you decide which is best.
  13. Nov 5, 2022 at 6:22 PM
    Mas Olas
    Woody
    Yes, a truly epic and historical feat! I seem to remember OP asking for info on how capable his rig is and how to use the different buttons. It isn’t advisable to figure these things out when stuck in 10” of snow but BRAVO for his effort! I sure as hell wouldn’t have made it home being from the beach in SoCal.
    Benny blanco[QUOTED] likes this.
  14. Nov 5, 2022 at 6:45 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You were stuck and didn’t use any of the specialized off road features of your truck and you want advice on how to not get stuck??
  15. Nov 5, 2022 at 6:51 PM
    #35
    MGMDesertTaco
    Lots of good advice already given. I'll agree with traction boards, better tires and momentum. Plan your path out ahead before you get into a situation that makes you slow down and get stuck.
  16. Nov 5, 2022 at 7:13 PM
    #36
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Oh, I get it now. Read the owners manual. The acronyms can be confusing. VSC and TRAC, (both would’ve been off in 4lo, but what the fuck is ATRAC and the locker is just another thing up there on the console. But also doesn’t sound like op was too concerned nor was the trail that bad. Also I think op has good back up plan in place.
  17. Nov 5, 2022 at 7:24 PM
    #37
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You can’t put chains on the front wheels of a stock off-road 3rd Gen Tacoma (UCA’s are too close to the tires).:annoyed:I hate this!
    “Throttle out”, do you mean don’t spin the tires? Hope so, there have been some grenaded differentials from people over throttling and spinning their wheels to get unstuck out of snow. You get a lot more traction not spinning them.
    vicali likes this.
  18. Nov 5, 2022 at 11:13 PM
    #38
    suomiM31
    suomiM31 [OP] Well-Known Member
    This is a road deactivating cross ditch. When th nose of my truck is at the bottom of the ditch, the back wheels are on the downward slope of the ditch. I have never seen a cattle guard large enough to span such a ditch.one would need a sizeable truck and some type of cane to put into place I believe. I agree the high speed solution would not end happily.Thank you for your time and suggestions though.:thumbsup:
  19. Nov 6, 2022 at 4:40 AM
    #39
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    4LO, rear locker, ATRAC on. Air down. If that fails you use your buddy or a winch.
  20. Nov 6, 2022 at 5:27 AM
    #40
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Tires tires tires. What tires do you have on? Based on your description you should have SNOW tires. Not just all terrain of off-road tires. I have about 30K on my Falken AT3W and am thinking this will be the last season I can get away with those. And that’s only for around town. Where you are going you need good snows.
