Tire Air Pressure Idiot Light is On
Discussion in 'Wheels & Tires' started by saf023, Oct 17, 2009.
  1. Oct 17, 2009 at 8:33 PM
    saf023
    saf023 [OP] Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Drive my truck yesterday and no air pressure idiot light; today my wife and I were on the rode and it came on. I stopped at a gas station and had to pay 75 cents for fricken air. The tire air pressure gauge did not work and I had mine in another car. I went ahead and put some air in the tires and figured I'd check pressure when I returned home. After putting the air in the tires the idiot light remained on. When I got home I checked tire pressure and it was fine.
    Anyone have any suggestions?
    Thanks.
  2. Oct 17, 2009 at 8:35 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    spare tire
  3. Oct 17, 2009 at 8:35 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    check the spare.
  4. Oct 17, 2009 at 8:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x3....spare is usually the damned culprit.
  5. Oct 17, 2009 at 8:38 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep, check the spare. Also, alot of times all it takes is a temperature change to set the dam thing off. Did it just get colder where you are?
  6. Oct 17, 2009 at 8:39 PM
    saf023
    East Coast
    Good point. I didn't think to check the spare. It's continuing to rain like crazy so I'll have to wait until it stops but I hope that turns out to be the issue.
    Thanks.
  7. Oct 17, 2009 at 8:39 PM
    ccoorreeyy
    ccoorreeyy www.EvolvedFinance.com
    Corey
    Los Angeles (South Bay)
    08 Double Cab 4x4 SR5 Debadged
    BHLM, Revenge Fab Rock-Sliders, BFG TA KO's, N-Fab light bar with 4 Hella 500's, Rear Suspension TSB, TRD Exhaust, CB Radio, 100W Ultra bright headlights, JBL Sound
    Try the reset button.
  8. Oct 17, 2009 at 8:45 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    small piece of black tape
  9. Oct 17, 2009 at 8:52 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    And unless you have already done it, you will have to completely remove the spare to get at the valve stem. I flipped it over before putting it back so I can check it without dropping it down next time.
  10. Oct 17, 2009 at 8:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2...good way to do it.
  11. Oct 18, 2009 at 4:36 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    x3 the much easier next time mod :D
  12. Apr 25, 2010 at 7:00 PM
    MK ULTRA
    MK ULTRA Well-Known Member
    JIM
    Huntsville Ala
    4X4
    That doesn't make any sense.
    Did you get a spare or not??
    If you did not you need to go back and get one. I promise you that they charged you for one.
    A tank of fuel won't even begin to pay the price of a wheel and tire.
  13. Apr 25, 2010 at 7:29 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I find it amusing that you call it an idiot light yet post a question to ask for suggestions.:help:
    If the spare air pressure is correct and the light doesn't reset, likely a bad sensor. Have any tires changed recently?
  14. Apr 25, 2010 at 7:38 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If one of the sensors is bad, theoretically the light should blink rather than remain on.
  15. Apr 26, 2010 at 2:40 PM
    Fortech
    CANADA
    Could be possible, thankfully my '05 don't have the dreaded system - therefore no info to reference in my owners manual either. I would assume however that the OP can find the info they require in their own manual.
  16. Apr 26, 2010 at 2:47 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    You also have to reset the light after you put air in, the button is below the steering column.
  17. Apr 26, 2010 at 3:08 PM
    Hunter423
    Hunter423 Hunter423
    hunter
    TN
    2008 Tacoma TRD off road
    brush guard, piaa foggs, tinted tail light, tinted windows, rain guards, pure white with blue tinted bulbd all over, white bulbs for licencess plate lighting, blacked out head lights
    yea spare of if you have put on new tires and wheels that could do i have a spare set i use for off roading and when i have them on the light comes on
  18. Apr 27, 2010 at 5:41 AM
    MK ULTRA
    JIM
    Huntsville Ala
    4X4
    Was this "LOW TIRE PRESSURE" idiot light an Obombo mandate?
    He did say on national TV: This is from memory
    "IF YOU JUST KEEP YOUR TIRES INLFLATED YOU CAN SAVE AS MUCH GAS AS THE OIL WE CAN PUMP OUT OF THE GROUND".
    Then Toyota puts idiot lights on their 2008 vehicles.
    Just sayin....
  19. Apr 27, 2010 at 5:52 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    I think they started coming on the 06 model year. I know mine has them.
    I've heard of people removing them all, sticking them in a short piece of PVC pipe with a valve, and filling the pipe full of air pressure. Keep the pipe in your bed, and the sensor light stays off.
  20. Apr 27, 2010 at 8:14 AM
    1980
    1980 Well-Known Member
    The Dust Bowl
    I, for one, like the sensor light. Sure, once when the weather turned really cold the light came on from the spare tire but it took only 5 minutes with the cheap 12-Volt air compressor I have to turn it off. However, the other time the light came on I got out and checked and, sure enough, I had a roofing nail in my right front tire.
