Tire Balance Problem
Discussion in 'Wheels & Tires' started by abear0232, Jun 28, 2008.
  1. Jun 28, 2008 at 8:22 AM
    abear0232
    abear0232 [OP] New Member
    Baton Rouge, Louisiana
    07 PreRunner SR5 Sport
    I have a 2007 Tacoma, double cab, Sport. It has Bridgestone Dueler AT tires. The truck has 7500 miles, and had balance problems since I bought it. The dealership replaced two of the tires, due to excessive road force. They still cannot get the tires balanced correctly. Keep getting steering wheel shake. I have brought the truck to the dealership 6 times for this problem. Can anyone give me some advice, before I take legal action??
    Thanks
  2. Jun 28, 2008 at 8:32 AM
    rick
    rick `
    hmm. tacomaman06 is having the same problem. my advice is stay away from bridgestone
  3. Jun 28, 2008 at 9:34 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've run Bridgestones on other vehicles without any problems...
    Have you rotated the tires to see if you feel a difference in the vibrations?
    Can you narrow it down to one or two of the wheels/tires?
    Perhaps a 'wheel' is bad....?
    I always mention this, but the next time you get them balanced...suggest to the guy once he is done balancing the wheel....ask him to rotate the wheel 180 degrees on the machine and spin it again (to verify and fine tune the balance).
    If none of that works - I'd highly suggest you force the dealership to put another set of wheels & tires on the truck from another vehicle. This will help you identify whether or not its the wheels/tires OR perhaps something si wrong with the truck itself.
    How about they check the allignment?
  4. Jun 28, 2008 at 9:50 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Words of wisdom from Janster :)
  5. Jun 28, 2008 at 9:52 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Same here. Bridgestone and Firestone (same company) have some great tires. I haven't had a problem with them yet.
  6. Jun 28, 2008 at 10:10 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im having the same problems also.............get the dealer to recheck the alignment, then make sure your lugnuts are torqued to the correct specs., and try adjusting the air pressure to see if that makes a difference first
    the bridgestone revo's are an awesome tire..........but i had a set of goodyear wrangler silent armors.......same problems with them......both the revo's and wranglers had 2 tires in the set that had high roadforce......sounds like bs to me though. i find it hard to believe that from 2 consecutive new sets of tires.....both sets are bad!!!
    you may end up having to take action amn......or keep the tires with the high roadforce in the rear......you wont be able to feel the shaking then. let us know what you do and what happens!!!
    im behind you on this one for sure!!!
    this is one reason, along with alignment issues, that im gonna trade outta my lease for an 04 4x4 tacoma!!!
  7. Jun 28, 2008 at 5:04 PM
    gpspowell
    gpspowell Well-Known Member
    Denver, CO
    08 4WD TRD Off Road
    TRD Supercharger, TDR CAI, TRD Cat Back Exhaust, Old Man Emu 2 1/2" lift kit (886s & Dakars), Full All Pro armor inc. locker guard, Custom fuel tank armor, All Pro Rock Sliders, ARB front bumper, IPF 800XS Driving Lights, Ramsey REP 8000 winch, Centerline wheels, 285X75X16 Michelin LT AT2s, Snug Top shell, SoundLinQ audio interface for my iPod.
    Any chance you guys are running wheel spacers?
  8. Jun 28, 2008 at 5:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no wheel spacers for me. and its stock prerunner height also.
  9. Jun 28, 2008 at 5:31 PM
    Janster
    Jandy
    Lancaster, PA
    Anybody try to run Equal ?
    We've been running Equal in our BFG M/T's (35's) on our jeep for years.
    Granted - it's not a daily driver but it's been on the highway countless times up to 70mph without any problems. You just gotta get the proper amount in each tire to balance properly.
    We bought the wheels/tires mounted & balanced and drove 'em home from N.J. The person who balanced them put 3 layers of stick-on weights on the inside of the wheel. :rolleyes: Well, the weights were hitting the calipers. So instead of hauling back to N.J. - our local shop guy suggested Equal.
    Before you guys go and try this - better find out if it's compatible with the TPMS. Gawd knows, those little granuals might interfere with the TPMS.
  10. Jun 28, 2008 at 5:38 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    I had never heard of it before now. Do you have a link to some info on it?
  11. Jun 28, 2008 at 5:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    is it kinda like dynabeads, janster??
  12. Jun 29, 2008 at 5:34 AM
    Janster
    Jandy
    Lancaster, PA
    Yup... I guess dynabeads are ceramic and Equal is dry polymer.
    This is the only site I could find on it...(I didn't spend too much time looking)
    http://www.expeditionexchange.com/equal/
    Makes me wonder if you can use it with the TPMS. On the jeep - we have a special valve that has a filter on the end of it to prevent it from coming out the valve when you let air out. Airing down requires removing the valve so the air comes out faster (the filter gets clogged and air doesn't come out as fast).
    Here's a brief site I found about the two together...
    http://www.moderntiredealer.com/t_inside.cfm?action=art_det&storyid=1397&pgNum=1
    But - depending on what type of TPMS system it is on the trucks.... I wonder if anyone at Toyota would have a clue about this?
  13. Oct 19, 2008 at 1:31 AM
    notbrigum
    notbrigum Well-Known Member
    Chandler AZ
    08 double cab 4x4
    TRD intake, Magnaflow exhaust, billet grille, tube steps
    Just trying to help, this started with a prob about highspeed wheel shake. My new 08 double cab 4WD did the same. Seems to be balance in the tires. Re-balanced tires 4x (three times dealer Roadforce) but the prob now seems to be gone. Dealer shop manger admits the Tacoma is very sensitive to tires being perfectly balanced or it shakes. Good luck.
