Tire Balancing Weights
Discussion in '1st Gen. Tacomas (1995-2004)' started by low12, Jan 29, 2010.
  1. Jan 29, 2010 at 10:26 AM
    low12
    low12 [OP] Active Member
    RUFFIAN
    Virginia
    Prerunner SR5 V6
    :confused: What is the PROs and CONs of the Balancing WEIGHTS on the tires installed inside (none installed outside to keep the RIM clean)? Is there a lot of vibrations on the tires as a result when driving at high speed, like <70 MPH ? Or is it improperly balanced? Anybody have this problem? Thanks. So Mote It Be.
  2. Jan 29, 2010 at 10:29 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    I have them on the inside / middle of the rims on my mustang, and have never had an issue all the way up to 100+ mph.
  3. Jan 29, 2010 at 10:40 AM
    misterquad
    misterquad Well-Known Member
    Being a Traveling man I would agree
  4. Jan 29, 2010 at 12:40 PM
    low12
    RUFFIAN
    Virginia
    Prerunner SR5 V6
    Have you travelled to the east misterquad?
  5. Jan 29, 2010 at 12:43 PM
    low12
    RUFFIAN
    Virginia
    Prerunner SR5 V6
    misterquad, will you be off or from?
  6. Jan 29, 2010 at 12:46 PM
    misterquad
    I have only recently begun my jouney.
  7. Jan 29, 2010 at 12:59 PM
    low12
    RUFFIAN
    Virginia
    Prerunner SR5 V6
    Continue your journey sir, even if you trip or fall it will be meaningfull and worthwhile. The best thing that I ever experience in my entire life. I wish you the best.
  8. Jan 29, 2010 at 1:04 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Having them mounted on the inside of the rim makes a cleaner look and they are less likely to be scrapped off if you run up against a curb. Since I have my TPMS strapped to the inside of my wheel I had to put weights on the outside as well as the inside of the rim.
    As far as driving at high speeds, I have had my truck up to 125 mph (legally on the Autobahn) there is no vibrations at all.
  9. Jan 29, 2010 at 1:13 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    Local shops here refer to that as a simple balance, what Ive been told is that a proper balanced wheel should have weight on both sides of the wheel and if you want clean look put the outside weights inside the wheel but as close as possible to the wheel spokes
    I had vibrations from 50mph +,I took it to a different shop and they told me what I mentioned above, they told me the wheels were balanced but it was a "simple balance job" they balanced the wheel as I mentioned above and the vibrations disappeared.
    some more info
    http://www.discounttire.com/dtcs/infoTireBalancing.dos
  10. Jan 29, 2010 at 3:27 PM
    mx04taco
    mx04taco Well-Known Member
    Cory
    Marietta,GA
    04, SR5, TRD, 4wd
    Flowmaster exhaust, Pioneer DVD HU, Pioneer speakers all around, , Viper security w/ remote start, Tinted Windows, Silverstar Headlights, Toytec 3" Coil Springs, All Pro Offroad Diff Drop 3/4", Bilstein 5100s, 2" Toytec AAL's, Toytec poly rear leaf bushings, Deckplate Mod 4", 265/75r16 firestone destination a/t's
    no real cons, but the only pro is no wheels weights on the outside face of the wheel. Its much cleaner and yes those outside wheel weights do scratch the lip of the wheel while being installed.
