Tire chain advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Komrade, Feb 10, 2014.
  1. Feb 10, 2014 at 10:08 PM
    Komrade
    Komrade [OP] Well-Known Member
    13 DBCB 4x4 MT
    I live in the part of the country where snow isn't very common. But it does snow occasionally, and sometimes it snows on top of existing snow right around 32F, which makes it especially slippery.
    I do have a cabin at a bottom of a hill, and Taco with stock tires can't really make out on it's own. I was rather lucky this weekend when it slid a good 40-50 feet, but goт saved when it got stuck in a side ditch (really lucky, as the other side of the gravel driveway is a ravine). Putting couple of 200lb of stones in the back didn't help when I tried to go up the slightly less steep driveway (it's a shoe horn driveway). Breaking ice and shoveling of about 100 feet of driveway followed.
    In my opinion, mud or snow tires aren't really worth the upgrade, as mostly, I'll just be wasting MPG in the winter (due to no snow). Locking differential may help, but not sure if as much as extra traction provided by the chains. In general, better tires may help as discussed in this thread, but I only have 7K on these, and would really prefer not to replace them prematurely. They perform adequately in dry and wet conditions.
    I am interested, of course, in the best bang for the buck, and those that are "easy on, easy off". In the rare chance I'd actually want to put them on, I'd only need them for less than a mile.
    No offense to any advice or comment will be taken... Thanks.
  2. Feb 10, 2014 at 10:20 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
  3. Feb 10, 2014 at 10:24 PM
    Menj309
    Menj309 Well-Known Member
    Richard
    SoCal 909
    13 trd sport
    CB Radio
    Go with actual chains over cables
  4. Feb 10, 2014 at 10:37 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    if you're not in an area that is prone to much snow, maybe real aggresive tires aren't going to save you anything
    i live in an area where without super aggresive tires you're probably not gonna do so well in the winter
    the way i figure it, if i don't get stuck or spin out of control, whereas i would have with lesser tires, just once or twice... the more expensive and less mpg-rated tires will have already covered that difference
    anway... i did get some chains too...
    I bought these "quick" application chains
    they work pretty well
    they come with repair stuff in the kit you buy them in; so, it's almost like they are expecting them to fall apart on you eventually
    and it seems like that could be sooner than later
    but, my friend owns some ladder style chains that are all grade 8 steel; kinda like these:
    they are WAY more stout than mine, and we can put them on his truck every bit as quick, or quicker, than i can put mine on
    he says he can put them on without having to lift his tire off the ground; which is a big claim to fame of the "quick" application ones;
    i personally can't verify that and i would assume there may be cases where it wouldn't work
    if i could do it over, i'd go with his type
  5. Feb 10, 2014 at 11:07 PM
    Komrade
    13 DBCB 4x4 MT
