Tire Clearance
Discussion in 'Wheels & Tires' started by bmrandolph1s, Mar 14, 2012.
  1. Mar 14, 2012 at 1:56 PM
    bmrandolph1s
    bmrandolph1s [OP] Well-Known Member
    Brian
    Missouri
    2016 DCSB OR AT MGM
    Factory tires on a 2012 Taco w/Off Road package are P265/70R16 BFGoodrich which have a tread width and diameter of 8" and 30.6" respectively. I would very much like to put on P285/75R16 BFG TA/KO tires which have a tread width and diameter of 9.2" and 33" respectively. Would this be possible with just a 2in body lift? If not, what if I added a heavy duty bumper like from Shrock Works? It looks like the heavy duty bumpers dont come down as close to the front tires as the factory bumpers do, so it seems like this would minimize or eliminate any rubbing. Please let me know what you think and let me know if any of my data is wrong. I really don't want to lift much more than 2in. I don't want a monster truck, just a moderate lift to get it about as high or slightly higher than a full size truck.
  2. Mar 14, 2012 at 4:21 PM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    With stock wheels you will need spidertrax spacers other wise aftermarket wheels with 4.5 backspacing to clear the upper control arms...you will still have to trim a tiny bit ant remove mud flaps
  3. Mar 14, 2012 at 7:04 PM
    rossivey
    rossivey Well-Known Member
    North Texas
    06 Black DCLB 4x4
    i've got 285/70/17 and i'm pretty sure they're the same size around as the 285/75/16. i put a 3" OME lift on and it lifted it about 2.5" but i still had to trim quite a bit and do the cab mount chop on the driver's side. my wheels have 4.5" backspacing and the tires don't hit the UCAs. & my front mudflaps fell off a long time ago. Unless you go with the 6" lift, then your truck shouldnt look like a monster truck. mine doesn't
  4. Mar 14, 2012 at 8:19 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    I am running 285 trail grappler M/T's and rub a little bit at full lock in reverse...nothing to make me chop...but then again i don't wheel offroad....strictly pavement. IMO 2-2.5" of lift with correct backspacing should be fine to fit a 285
  5. Mar 15, 2012 at 6:07 AM
    bmrandolph1s
    Brian
    Missouri
    2016 DCSB OR AT MGM
    Cool thanks for the info. Ya I want to keep the factory wheel but I'm not familiar with wheel back spacing. Could you explain that a little. To me it sounds like something that pushes the wheel out a bit from the axle. But I could be way off.
  6. Mar 15, 2012 at 7:09 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Just do a couple google searches until u feel comfortable with it. But less backspacing ex: 5 to a 4 will push the wheel away from truck or UCA..keeping the stock wheels most people use spidertrax 1.25 spacers around $200.oo for 4.
  7. Mar 15, 2012 at 7:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sticky at the top of this sub forum will help you understand backspacing.
    http://www.tacomaworld.com/forum/wheels-tires/102992-wheel-backspacing-offset-info.html
  8. Mar 15, 2012 at 7:18 AM
    bmrandolph1s
    Brian
    Missouri
    2016 DCSB OR AT MGM
    Gabe911, I went to spiertrax.com and found the 1.25" spacers for a tacoma. Is that what you were talking about? And I would need to get spacers for the front and rear tires correct?
  9. Mar 15, 2012 at 7:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just the front and make sure they are HUB CENTRIC
  10. Mar 15, 2012 at 7:23 AM
    bmrandolph1s
    Brian
    Missouri
    2016 DCSB OR AT MGM
    Ok got it. Thanks a lot
  11. Mar 15, 2012 at 7:24 AM
    bmrandolph1s
    Brian
    Missouri
    2016 DCSB OR AT MGM
    98Tacoma,
  12. Mar 15, 2012 at 7:25 AM
    bmrandolph1s
    Brian
    Missouri
    2016 DCSB OR AT MGM
    98tacoma, if I just do the front won't the front wheels stick our farther than the rear?
  13. Mar 15, 2012 at 7:29 AM
    txduckhunter
    txduckhunter Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    Do a lot of guys just put them up front?
    It doesn't look goofy?
    I've been trying to decide to go with rims or spacers. But I plan on staying with 16" and I have no issue with the stock wheels anyway.
  14. Mar 15, 2012 at 7:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes. That's totally up to you though. Some guys do it for the aesthetic value, some don't. The rear will clear that tire fine without the spacers.
  15. Mar 15, 2012 at 7:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    From what I have seen, most just do the front.
  16. Mar 15, 2012 at 7:38 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    yes personal preference...I like em all out....IMO
