Tire decision???? need a lil help !!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devman80, Nov 8, 2012.
what would you choose?
  1. dick cepek Radial F-C II
    8.7%
  2. stock tires
    1.3%
  3. bfg t/a ko 10 ply white letter
    38.7%
  4. bfg t/a ko 8 ply black wall
    52.7%
  1. Nov 10, 2012 at 4:05 PM
    #61
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    duratracks :spy:
  2. Nov 10, 2012 at 6:20 PM
    #62
    devman80
    devman80 [OP] Well-Known Member
    Dev
    newfoundland
    toyota tacoma long bed trd(leather)
    otto-navi head unit, 3 inch level/lift, constant power to cig lighter and 12v outlet, toyota accessories bug deflecter , steps , vent visors, and fabtech street bar with 4 hella black magics upgraded to 100w each .. and 1.25 spidertrax all around.
    thanks!!
  3. Nov 10, 2012 at 8:53 PM
    #63
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto.
    You want the BFG, get the BFG.
    10 ply is a great tire... if you have a 3/4 ton fullsize and tow a 30ft toy hauler.
    The Tacoma suspension will max out long before you max out the 8-ply, and they will ride a lot better than the 10 ply, not to mention cheaper and lighter for better MPG.
  4. Nov 11, 2012 at 5:51 AM
    #64
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    Ok, had them installed yesterday. They look really nice and can't wait to hit either the snow or trails.
    I got 265/75 R 16 E rated, make a sweet hum went I hit the freeway. Ride is about the same, maybe a little firmer, but feel like they should.
    My only concern is the front tires, there is only a finger width clearing between the inside of the tire and the front end hardware. No rubbing but could never fit chains on there if the need arose.
    How does one get more room in there?
  5. Nov 11, 2012 at 6:23 AM
    #65
    Two Tall
    Two Tall Well-Known Member
    Jim
    Ohio
    2018 TRD Off Road DCSB 4x4
    Retrax MXPro bed cover, Gentex Homelink mirror, TRD exhaust
    My opinion, yes to harder on gas.
  6. Nov 11, 2012 at 6:33 AM
    #66
    Two Tall
    Jim
    Ohio
    But BFG A/T KO's on last 5 Tacomas....265/65/18 this time:
    TAC1 likes this.
  7. Nov 11, 2012 at 6:38 AM
    #67
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    Goodyear Duratracs Just had our first snow fall and amazing traction.
  8. Nov 11, 2012 at 7:29 AM
    #68
    FrozenTaco
    FrozenTaco Member
    Frozen
    Canada's Yukon
    2013 TRD Sport, mgm w/leather DCLB 4.0L AT
    I put 200,000 kms on BFG T/A KO tires with my Dakota and will be having the dealer install a set on my Tacoma before I take it off the lot later this month. The tires I used with my Dak were load range E and were fantastic in the mud, snow, ice and on the highway. Some noise, but better than many other all terrains. Mileage suffers somewhat over a highway tread but I can live with that. I got a minimum of 70,000 Kms from each set without a single flat on any of them. The BFGs have excellent sidewall strength, which I have thought about often when in frost shattered rock up mountain trails.
    We use these on our fleet also, and every one I've seen come in has had RWL on one side and BSW on the other.
    The only load range I see listed for LT265/65R17 is "E", and this is the size of tire my 2013 TRD is going to arrive with.
    I would think the higher the ply rating, the better the fuel mileage as the tire would be stiffer with less flex, therefor less rolling resistance.
    "Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply." - TireRack.com
  9. Nov 11, 2012 at 7:33 AM
    #69
    devman80
    Dev
    newfoundland
    thanks for the feed back guys... leaning more for the 10 ply bfg ta/ko white letter!!
  10. Nov 11, 2012 at 7:28 PM
    #70
    geoff7877
    geoff7877 Well-Known Member
    Petaluma, CA
    2018 TRD Off Road 4X4 Double Cab
    Bad ass. I love that look. That's exactly what I want when I replace the stock dunlops. What is the rating on those. I've seen those in LT, E, Q etc.
  11. Nov 22, 2012 at 2:50 PM
    #71
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    I have load range "D" in same size....White on one side...black on the other.
  12. Nov 22, 2012 at 2:55 PM
    #72
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
  13. Nov 22, 2012 at 5:36 PM
    #73
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I love my Dick Cepek Crushers,They have skulls! And they do have white letters just turned them in. 10 ply. Ride great
  14. Nov 22, 2012 at 9:02 PM
    #74
    MrTacoma
    MrTacoma Well-Known Member
    Tacoma Base v6
    None
    I had to replace my michelins tires in September, I switched over to Continentals...there pretty good ride..they did good in the snow do good in the rain, I can't complain ..I make sure there @ 32 psi weekly like truck door says to keep em..had them for 2000 miles they were 600 for me so I might keep using them for rest of truck life.
  15. Nov 25, 2012 at 5:23 PM
    #75
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    I have Dick Cepeks on my 87 Toyota and love them
  16. Nov 26, 2012 at 11:18 AM
    #76
    devman80
    Dev
    newfoundland
    lt285/70/r17 10 ply bfg t/a ko white letter 1300 sumthin taxes in installed... i think thats whats going on.... the winter tire/rims are going on very soon.. gonna buy them up over the winter..
  17. Nov 26, 2012 at 11:25 AM
    #77
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    Check out the Kuhmo Road venture A/T 285/75/16.. They weigh much less than most 285's and their tread is actually really aggressive for an all terrain tire
  18. Nov 26, 2012 at 2:16 PM
    #78
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    I have KM2's, 255/85's............I like the higher load rating as I have torn the sidewall on rocks more often than I have liked.
  19. Mar 26, 2013 at 9:37 PM
    #79
    2013 2.7
    2013 2.7 Well-Known Member
    13 PreRunner
    How bad will i rub if i put 285's on my stock prerunner
  20. Mar 26, 2013 at 11:01 PM
    #80
    gwos25
    gwos25 Well-Known Member
    Gary
    Calgary, AB
    2012 TRD Sport
    Here's another vote for the General Grabber AT2. Much prefer them to bfgs they replaced.
