tire light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black cx, Dec 30, 2010.
  1. Dec 30, 2010 at 1:27 PM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    The tire light with the exclamation mark on my dash came on. I looked at my tires and they look fine..any ideas? Should I bring it into the dealer
  2. Dec 30, 2010 at 1:36 PM
    TacomaMan07
    TacomaMan07 Well-Known Member
    Chandler
    Tuscaloosa, Alabama
    07 PreRunner SR5 DC
    Black Toolbox; Bed Mat; BFG ATs 265/75/16
    My light has been on the last 3000 miles. Nothing to worry about IMO.
  3. Dec 30, 2010 at 1:37 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    :laugh:
    My taco does it when ever the outside temp drops hardcore in the mornings... After driving for a bit it will usually go away.
  4. Dec 30, 2010 at 1:41 PM
    TacomaMan07
    Chandler
    Tuscaloosa, Alabama
    07 PreRunner SR5 DC
    Thats why my dad pays for AAA.
  5. Dec 30, 2010 at 1:41 PM
    ::childstoy::
    Southeast, PA
    Hold on wait.... Really?
    Thats censored too???
  6. Dec 30, 2010 at 1:48 PM
    11B4X4
    11B4X4 Well-Known Member
    Northern VA
    2006 tacoma 4x4, Black
    Trd intake, Doug Thorley offroad headers, magnaflow exhaust, RBP running boards, 2.5In spacer, URC O2 simulator, 5100's all around
    If you drove through some deep water recently you could of fried a sensor. The dealership can replace them if you have a warranty.
  7. Dec 30, 2010 at 1:51 PM
    tanzak88
    tanzak88 Well-Known Member
    Tanner
    BC, C-eh-N-eh-D-eh
    :goingcrazy:
  8. Dec 30, 2010 at 2:02 PM
    JKD
    JKD Well-Known Member
    Explain, please, how driving through deep water could have "fried a sensor" that is sealed within the tire?
  9. Dec 30, 2010 at 2:03 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    I just looked at them Haha
    How much psi should be in the tires?
    does it turn off by itself?
  10. Dec 30, 2010 at 2:10 PM
    TacomaMan07
    Chandler
    Tuscaloosa, Alabama
    07 PreRunner SR5 DC
    I think my PSI was like 32 or so when I checked them about two weeks ago. Does that sound about right?
  11. Dec 30, 2010 at 2:16 PM
    DTP
    DTP Member
    Damon
    Tijeras, New Mexico
    01 Tacoma 4x4
    cb, highlift jack, bilstein 5100, ome 881coils, 2.5 inch rear lift
    that sounds right i run 30 in the front and 35 in the rear. my other half has an 06 tundra running the same pressure, the light comes on mostly when cold or the spare is low (don't know why)
  12. Dec 30, 2010 at 6:26 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    i inflated the tire back to 30psi...is the light suppose to reset itself?
  13. Dec 30, 2010 at 6:27 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    There's a reset button below the steering wheel.
  14. Dec 30, 2010 at 6:52 PM
    g man
    g man Member
    nw florida
    2.7 tacoma 5 speed
    I believe the tire pressure monitor system will have to be re set, your manual tells you how, I believe there is a button under the dash (driver's side) that you press and hold to reset. Also if you check the drivers side door jamb you will find the recommended pressure.
  15. Dec 30, 2010 at 7:37 PM
    11B4X4
    Northern VA
    Not sure but water has destroyed about three of mine. as soon as i would go through water about half way up my tire the light would go on. went to the dealer they said i had a bad sensor..each time
  16. Dec 30, 2010 at 7:44 PM
    KPT
    09 Prerunner
    Did they find water in the tire? Bad bead?
    If so your tires should get low fairly often.
  17. Dec 30, 2010 at 7:52 PM
    11B4X4
    Northern VA
    No, they didn't say there was any sign of water damage and my tires hold pressure fine. did it with my old tires and new. I didn't know the sensor was inside. I know the TPMS is inside, i always figured there was another sensor of some kind more exposed
  18. Dec 30, 2010 at 8:03 PM
    11B4X4
    Northern VA
    Fix a flat...what do you take me for a barbarian! idk what happened, continuing problem though
  19. Dec 30, 2010 at 11:49 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    found the culprit...nail in the sidewall
