Tire low pressure.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by perchie15, Apr 24, 2012.
  1. Apr 24, 2012 at 5:06 PM
    perchie15
    perchie15 [OP] Well-Known Member
    Joey
    Alberta
    TRD
    None,
    K it's time I've asked or said something. But ever sense I put on new tires LT265/70R16 my low tire pressure light stays on!!! Why?
  2. Apr 24, 2012 at 5:10 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    did whoever did your tires use the stock stems? They have the built in sensors. Also, make sure you check your spare tire as that has a sensor too
  3. Apr 24, 2012 at 5:16 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    1) One (or more) of your tires is low
    OR
    2) Whoever installed your tires broke a sensor
    Does the light flash for ~30 seconds and become solid, or flash once and then become solid? This will greatly help me in answering your question more thoroughly.
  4. Apr 24, 2012 at 5:24 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    is the pressure close to the same in all 5 tires and have you tried the reset button?
  5. Apr 24, 2012 at 6:04 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Best answer. And before you ask.. it is in the manual.
    Frank
  6. Apr 24, 2012 at 6:34 PM
    perchie15
    Joey
    Alberta
    TRD
    None,
    Yea under the steering wheel. It's been on ever since new tires been on. N no they didn't use stock stems. I bought rims n tires for just winter...
    Yea I have checked all tires Ofcourse but thx.
  7. Apr 24, 2012 at 6:41 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    If they didn't put your TPMS (TIRE PRESSURE MONITORING SYSYTEM) in the new rims, then the tire pressure light will stay on, as there is no sensor readings to say your pressures are good. You need to have them installed, or wait till you get your "summers" back on. Tape over the light may help till you can decide. I would also suggest you spend some more time with your manual. It covers the basics pretty well. Best of luck.
    Frank
  8. Apr 25, 2012 at 9:05 AM
    OffroadToy
    4X4 Offroad
    The stems in your old wheels were the tpms sensors...without them (or the correct replacement) your system will not function. Do you still have the old tires/wheels? Also, didn't the place that put the new wheels on say something about sending you down the road with the tpms system not working like it was when you drove in?
  9. Apr 26, 2012 at 7:24 AM
    perchie15
    Joey
    Alberta
    TRD
    None,
    I did have a steal wheel on for winter, I just put my summer rims and tires back on and about to go out for a drive hasn't went off yet so maybe when I start moving it might go out cuz I tied the button n nothing. (can't find manual) no kal tire did not mention nothing!!weird why they didn't!! Nope didn't say nothing!!
  10. Apr 26, 2012 at 9:28 AM
    OffroadToy
    4X4 Offroad
    Here's the 2007 owners manual...
    http://www.toyota.com/t3Portal/document/om/OM35869U/pdf/07omsour/2007/07tacoma/17.pdf
    See page 32..."Tire pressure warning system". Make sure all tires (including the spare) are at the same psi and follow the instructions for resetting. Hope that helped.
