Tire Pressure Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by textoytaco, Oct 12, 2011.
  1. Oct 12, 2011 at 8:36 AM
    textoytaco
    textoytaco [OP] Member
    Houston, Texas
    08 Tacoma Double Cab 4x4
    My tire pressure sensor light stays on constantly. I reset the sensor and it stays off for about three seconds and comes back on. It was on before I bought new tires and it is still on now.
    I like the black electrical tape and pull the led ideas, but I'm wondering if anyone had luck getting the dealer to fix it.
  2. Oct 12, 2011 at 8:40 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    check and see if you have a TPMS sensor on the spare tire..sometimes some manufacturers design them to go off even when the spare is low..if you dont have one on the spare,then inflate all of the tires to the correct psi and drive about 50 miles so it can try and reset...also,have you got your tires rotated recently? i work at a tire shop so we always ask these questions
  3. Oct 12, 2011 at 8:42 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Check your spare. Mine will turn on if the spare tire pressure gets low.
  4. Oct 12, 2011 at 8:59 AM
    textoytaco
    Houston, Texas
    I am using stock wheels. I have checked the spare. I have driven for thousands of miles and tried to reset the light with no success.
  5. Oct 12, 2011 at 9:10 AM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    yup i think its time to visit the stealership to see if they can just reset it for you..by now the light should be off
  6. Oct 12, 2011 at 9:14 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    One of the sensors in the wheels may be defective (or just has a dead battery). The dealer should be able to figure it out with the handheld reader.
  7. Oct 12, 2011 at 9:25 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
  8. Oct 12, 2011 at 9:30 AM
    saugus
    saugus Well-Known Member
    Are you kidding me? These things have batteries that need to be replaced? So every time you replace them, do you have to reprogram them too?
  9. Oct 12, 2011 at 9:30 AM
    Brunes
    Brunes abides.
    Rotorhead
    You will know this before you take it to the dealer-The TPMS light will flash for like a minute after putting power to the truck before going solid. If it just comes on solid and stays on- It is a pressure issue.
  10. Oct 12, 2011 at 9:34 AM
    saugus
    It sure was nice of the Pep boys mechanic to try to fix my sensor light problem yesterday by inflating my tires to 40 psi.:frusty:
  11. Oct 13, 2011 at 6:07 AM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    lol pep boys fail again...we shouldnt inflate more than the psi thats directed unless you have a leak in a tire,even then its still not really a great idea.
  12. Oct 13, 2011 at 2:39 PM
    KenLyns
    Belly of the Beast
    The TPMS sensor has to wirelessly transmit the pressure reading to the ECU in the truck, so a power source is necessary. The battery is normally quite long-lived, so you get the battery replaced when you get new tires mounted. However, there are statistical outliers and possible temperature effects.
    The sensor does not lose its ID when you replace the battery, so you shouldn't need to re-register it with the ECU.
  13. Oct 13, 2011 at 6:24 PM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    from some manuals i read at work,the batteries recharge themselves..for example like on a watch,some of them dont require a battery because when the watch has motion it will charge from the motion..but then again,that may only be on some designs and not all..it may very well have an actual battery
