Tire Pressure Sensor from 07 to 2011?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Polarisman, Oct 7, 2010.
  1. Oct 7, 2010 at 8:20 PM
    Polarisman
    Polarisman [OP] Active Member
    Vidalia,LA
    07 TRd Sport Double Cab 4X4 with Factory 20's
    Factory Toyota 20 inch rims, on Bridgestone Tires In channel Ventvisors, Window Tint, Bed Mat, Running boards
    Hello everbody,
    I have an 07 Tacoma Double Cab TRD Sport and im selling it to get a 2011 double cab TRD Sport, I currently have the 20 inch Toyota wheels on my 07, but want to swap them to the 2011 and put the 2011 wheels and tires on the 07 (I sold my original TRD Sport Rims and Tires), my question is, do i need to break all the tires down to change the Tire Pressure sensors also, or can i just do a simple wheel swap and use the 07 sensors on the 2011 and the 2011 sensors on the 07, if so, can they be reset?
    Any help would be greatly appreciated.
    Thanks,
  2. Oct 7, 2010 at 8:25 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    You are going to have the sensors assigned to your vehicle that you are putting the tires on. Each has it's own ID number and until they are input to your ECU the truck will not recognize them. They will work but have to be input to the new trucks ECM. Try and work into the deal with your dealer, that after you swap the wheels and tires they will assign the sensors to your new truck for free. I bet they will do that for you.
  3. Oct 7, 2010 at 8:27 PM
    Polarisman
    Vidalia,LA
    Can just a tire place do this, or only the dealer?
  4. Oct 7, 2010 at 8:30 PM
    Blackened Taco
    Tony
    Virginia
    Dealer only, they have to use a scantool to access your ECM. I set them up in vehicles all the time when NTB or whathaveya screw them up mounting new tires and break them. They put in the sensor usually and I will assign the sensor to the vehicle. Not a big deal. The sensors send a radio signal to the ECM, the ECM just has to know the ID number so that it will recognize it.
  5. Oct 8, 2010 at 11:34 PM
    Blackened Taco
    Tony
    Virginia
    After you get the ID's There is a laptop (scantool) that plugs in under the dash and you have to delete the previous ID's and insert the new ones. Then intiate it and voila it's back to normal. Before the scanner came out we had to break the tire down to get the ID numbers.
  6. Oct 8, 2010 at 11:56 PM
    Blackened Taco
    Tony
    Virginia
    As long as you are using the same wheels you are fine. You can change tires a 1000 times as long as you are using the same wheels. Sensors are your valve stems. 28 a tire is expensive, 17.90 is my mount and balance fee. If you do all four it's 69.95.
  7. Oct 11, 2010 at 8:23 AM
    Blackened Taco
    Tony
    Virginia
    Gotcha, I wonder if having a set of TPMS, sensors in both wheels in the long run would be cheaper.
