tire pressure sensor (spare?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by little red, Oct 8, 2011.
  1. Aug 16, 2012 at 9:54 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    I think the button simply changes the TPMS ECU warning threshold, in case you change to a different type of tire that requires a different normal operating pressure. There may be a "floor" in the ECU logic that won't set the threshold below, say, 10 psi. I think the sensor always gives an absolute pressure value, because some cars can display the pressure in each tire numerically in the dash, in addition to the caution light.
  2. Aug 16, 2012 at 9:55 AM
    KenLyns
    Belly of the Beast
    What's riskier, replacing the battery in a TPMS sensor, or replacing the battery in an iPhone? :D
  3. Aug 16, 2012 at 12:24 PM
    FTL911
    FTL911 Well-Known Member
    Paul
    SoCal
    06 PreDblCabTRDSport
    Thank you Ken, I didn't see that...Apparently after inflating what I thought was the problem tire; I found that I had over inflated the tire by 10 lbs (but only for an afternoon). My light was actually blinking and then stayed on.
    Now after bringing the tire pressure into spec and inflating the spare to the correct pressure. my issues have been resolved.
    With the next new tires I will be removing the TPMS from each wheel.
    The system is too costly to maintain and too stupid to continue to mess with.:mad:
  4. Aug 16, 2012 at 6:04 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No... they can be set within a certain range, but can't be set below, IIRC, 20 or 25psi.
    I have seen it recommended to deflate to 25psi, reset (and I think you need to drive for 15 miles or so), then reinflate to your normal 35-40 (or wherever you run) and you won't have to worry until you get down to 25, or there's a difference of more than 5psi between two tires.
  5. Aug 16, 2012 at 6:50 PM
    geoff7877
    geoff7877 Well-Known Member
    Petaluma, CA
    2012 SR5 4X4 Double Cab
    Thanks for the clarification. Knew it was a long shot but I thought it was at least worth asking.
    Cheers!
  6. Oct 22, 2012 at 12:41 AM
    RacerAV
    RacerAV Well-Known Member
    OC, CA
    '09 DCSB4x4 (sold)
    there are only two types of the TPMS sensors right? the ones for the steel wheels and the ones for alloys? buying a used set, and don't remember the details i looked up a while back...
  7. Oct 22, 2012 at 4:07 AM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    I have a 2010 AC SR5 and do not have a TPMS in the spare. I found out when I had a flat. The spare had never hit the ground and only had a couple pounds of air in it. I assumed it did have a TPMS - and you know what that means.
  8. Oct 22, 2012 at 6:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    2009 or 2010, the spare TPMS sensor was deleted.
  9. Oct 22, 2012 at 6:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    20 degree and 40 degree (I don't remember which is which).
    Buying online, there are different frequencies available... I'd stick with RockAuto.com if not buying from a Toyota dealer like Titus-Will or Toyota of Dallas.
    You will need to have your ECU programmed to read the new sending units. You can reportedly do this yourself with the $35 Techstream clone, or a decent tire shop should be able to do it for you.
    To do it yourself, you'll need the serial numbers from the sensors. The tire shop should be able to read them.
  10. Oct 23, 2012 at 6:00 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    20 degree on aluminum, 40 degree on steel
  11. Oct 25, 2012 at 6:56 PM
    StanBo
    StanBo Well-Known Member
    Stan
    Central NJ
    10 DCLB - 98 XJ 93 RX7
    Would you be able to read the current sensor ID tags with the cable?
    Also thanks for all of the great info. I was considering going with the Ateq quickset device prior to reading about the Techstream cable.
  12. Oct 25, 2012 at 7:47 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    ... ^^^ ... Good question ... replaced a 3GS battery by myself a long time ago ... probably TPMS x 4 is riskier ... :D
    Just need a low wattage (fine tip) soldiering pencil to work on an iPhone battery.
  13. Oct 25, 2012 at 8:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No... you can input them into the ECU, but the ECU won't read an unknown.
  14. Oct 27, 2012 at 9:39 AM
    StanBo
    Stan
    Central NJ
    Thanks for the heads up. I am considering the PVC mod to keep the sensors happy.
