Tire Pressure Sensors
Discussion in 'Wheels & Tires' started by MyTaco, Aug 21, 2008.
  1. Aug 21, 2008 at 4:11 PM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Is there anyway to bypass the spare sensor? My 285's call for 65psi and the stocker calls for 35psi...any way around it?
  2. Aug 21, 2008 at 4:19 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Not really.
  3. Aug 21, 2008 at 4:19 PM
    MooseTX82
    MooseTX82 Moose
    San Diego
    08 TRD Sport 4x4
    Airaid Intake, Magnaflow Exh System, Icon Front Coilovers, TC UCAs, BFG 285s on 17" MotoMetal 951s, ARB Bumper, Hella Running Lights, Alpine CD HU, 6.5 Front JL Audio, 1 10" Kicker powered by Alpine 4 channel Amp
    I got mine recalibrated when i put my 285s on.
  4. Aug 22, 2008 at 2:01 PM
    MyTaco
    Az
    08 Prerunner
    So how was that done....are you running a 285 for the spare too?
  5. Aug 26, 2008 at 10:28 AM
    MooseTX82
    MooseTX82 Moose
    San Diego
    08 TRD Sport 4x4
    The spare is in progress since i gotta mod out the spare holder to hold one that big. They were re calibrated by 4Wheel Parts so I couldnt tell you how.
    Moose
  6. Aug 26, 2008 at 8:29 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  7. Aug 26, 2008 at 9:30 PM
    MyTaco
    Az
    08 Prerunner
    I could probably get away with doing this to my spare until I get one to match the other 4....thanks!
  8. Aug 27, 2008 at 6:57 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I also have some 285's with the factory spare. I haven't had any problems with them giving false readings. The other day I used the chalk method to air up my tires and the light went off because I droped the rear pressure by atleast 6psi. The TPMS seems fine with my tires wonder if the one in the spare may not work, better for me.
  9. Aug 27, 2008 at 8:09 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I had 285's on with my stock spare for over a year. I put all 5 tires to around 40psi without problems until about a month ago. Battery died a couple times and now the damn light is flashing all the time even though I checked all 5 tires. Was thinking about checking again to make sure they were all the same, but I'll be getting new tires this week so why bother. :laugh:
  10. Aug 27, 2008 at 8:19 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Good luck with that piercedtiger. Those little problems from out of the blue are the worst.
  11. Aug 28, 2008 at 6:09 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Yeah, and I'm not about to pay the dealer $120 to figure it out. :rolleyes:
