tire pressure?
Discussion in 'Wheels & Tires' started by Menametony, Jan 20, 2009.
  1. Feb 4, 2009 at 11:39 AM
    sonjay
    sonjay Well-Known Member
    I just moved up to 36 on all 4. Max pressure for my tires is 65psi. Chris could you explain the chalk test? I'm guessing you just draw chalk on your tire and drive on it and see how much is making contact with the road?
  2. Feb 4, 2009 at 11:46 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    All of us on this thread are probably doing the right thing. It's the people that don't pay attention to their tire pressures that are the problem. JMO.
  3. Feb 4, 2009 at 11:56 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Here is an air pressure tech article off Tire Rack that still advocates using the door jamb regardless if the tires are oem or not for some reason. :confused: Maybe its a disclaimer of some sort so they don't get sued?
    They have a pretty good list of tech articles on their website.
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=8
  4. Feb 4, 2009 at 3:10 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    I've got my Dune Grapplers at 50 psi right now...
  5. Feb 4, 2009 at 3:11 PM
    Delmarva
    Tucson, AZ
    I'd google this, but I figured I'd just ask so it's on the board... :D
    What's the chalk method?
  6. Feb 4, 2009 at 3:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    http://www.automedia.com/Optimizing_Tire_Pressure/ccr20010801tp/1
    You'll need a piece of chalk, a tire gauge, a pen and a note pad. Make a chalk mark across the tread as pictured, on one front and one rear tire, and then drive a quarter mile or so in a straight line. Stop and study the chalk marks and note the pressure readings on the gauge. [​IMG]
    This tire shows over-inflation, having relatively intact marks at the shoulders while the center of the line is more worn. Ideally, the chalk would have faded evenly across the tread surface. Let out some air and try again.
    One simple method for finding the right pressure for your vehicle is to draw a chalk line across the tread, then drive a bit and check the line. Even wear is good, while the line fading in the center indicates over-inflation. Worst is when the chalk mark wears off at the outer edges (shoulders) first, meaning that the pressure is too low. Under-inflation lessens the tire's load capacity, can make for squirrelly handling and, most importantly, makes the tire run hotter. Hot tires tend to disintegrate, regardless of who made them. Consequently, it's better to err on the high side, even if ride quality may suffer and the tire wear pattern could be less than optimal. However, do not exceed the maximum pressure as stated on the sidewall—there can indeed be too much of a good thing.
    Once the lines wear off evenly, note those pressures for future reference. While the inflation must be identical for both ends of an axle, the front tires will often require a slightly higher pressure since they usually carry more of the weight of an unladen vehicle (most engines are up front).
    Gauging Pressure
    It doesn't really matter how accurate your tire gauge is as long as it's consistent and you use that same one every time. Also important for repeatability is to measure the tires either cold or warm, then stick with that measurement method since tire pressure vary quite a bit with temperature. Last, but not the least, if adding load to the vehicle, don't forget to add to the tire pressures accordingly.
  7. Feb 4, 2009 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The chaulk method should be done for every set of tires. Tire pressure for the vehicle will vary between makes of tires, and manufactuers.
  8. Feb 5, 2009 at 7:45 AM
    Delmarva
    Tucson, AZ
    Thanks... :D
  9. Feb 8, 2009 at 8:23 AM
    *ROCKER*
    *ROCKER* New Member
    OGDEN UTAH
    08 xcab trd sr5
    WILL 16's rub on calipers????????????????
  10. Oct 19, 2019 at 9:59 AM
    Davidmetcalf91
    Davidmetcalf91 Member
    David
    2015 Tacoma SR 4x4 5 speed.
    Lt 245 75 r16 I run 33.5 up front and 32.5 in the rear. Cold inflation only. I live in Montana so I figure an increase of at least 2 psi at after they've warmed up.
