tire psi for 285's and 18's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black cx, May 8, 2011.
  1. May 8, 2011 at 7:28 PM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    Whats the recommended tire psi for running 285's and 18's?
    I looked at the door but that is for stock size and the recommended is 30 psi
    thanks,
  2. May 8, 2011 at 7:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use the Chalk method to determin the psi for your tires. Pressure varies truck to truck, as some weight more than others, due to the way they are outfitted, or whatever.
  3. May 9, 2011 at 8:01 AM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    whats the chalk method?
  4. May 9, 2011 at 8:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    CHECKING TIRE FOOTPRINT WITH A CHALK LINE
    [​IMG]Park on level ground and aim front tires straight ahead. Draw a line completely across the tread.
    Pull ahead 2-3 tire revolutions or until the chalk starts wearing off.
    If the chalk mark is worn off equally across the width of the tread, the inflation pressure is correct.
    [​IMG]If the chalk mark is worn off more in the center than at the edges, as shown here, the tire is over inflated.
    [​IMG]If the chalk mark is worn off more at the edges than in the center, as shown here, the tire is under inflated.
  5. May 9, 2011 at 8:23 AM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    thanks!
