Tire Recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by muslmutt, Oct 8, 2015.
  1. Oct 9, 2015 at 10:42 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Throw the Hankook Dynapro ATM RF10's in there. I wanted a slightly more agressive tire vs the MS2's and the Hankook has fit the bill amazingly.
    Though with as much highway driving that i do, the MS2's might be my next tire as i have ALWAYS been impressed with them on my past vehicles.
  2. Oct 9, 2015 at 10:56 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    I'll throw in for the Hankook Dyna Pro ATMs as well. I got about 40k out of a P-Metric Set before I switched to Cooper ATPs.
    Towards the end the Hankooks got a little slick in the rain and snow. But new nothing seemed to stop them.
    The Coopers ended up burning out in just under 30k, worked great but they hit the wear bars and that was it.
    So right now i have the Fierce Attitude MTs (Basically a Good Year Duratac in a different pattern). Awesome tire, did lose some MPGs. But I'll be running them for the winter. The Hankooks have a bit more life left in them, so I have them on my Stock Rims and going to run them till the snow flies.... I also do about 100 miles a week, and occasional weekend warrior stuff.
    Honestly when everything burns out again I will go back to the Hankooks full time I'm thinking. Great all rounders mildly aggressive side walls and good tread pattern. Total I'll get around 45-50k out of them and for a P-Metric on a truck getting beat on quite a bit I wont complain.
    If you do any off pavement stuff I would really recommend an All Terrain since wet grass will stop a lot of all seasons/highway tires.
    Toyos are good but heavy, Coopers are good as well but I didnt get a lot of miles out of them, but others have so its a little weird. Nitto is owned by Toyo so they are good but heavy. Goodyear is pretty good as well but can be pricey. Duratracs sometimes wear funny and some people have sidewall issues when you throw it into the rocks. Keep a relatively tight tread pattern and you'll save on the highway for MPG but decent voids and sipping for the trails and wet/snow stuff.
  3. Oct 9, 2015 at 11:08 AM
    dawgomatic
    dawgomatic Well-Known Member
    Honestly you can't go wrong with any of these options...
    You've basically got two spectrum's of more road ready vs. more offroad ready
    Pick the spectrum that fits your needs the best and then shop around for best value or if you want the best get the michelins
  4. Oct 9, 2015 at 2:47 PM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    Another thumbs up for the MS2. I've got 40K miles on my set and they barely look worn. Probably get another 40K out of them.
  5. Oct 9, 2015 at 3:23 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Hankook dynapro best value for the money. Aggressive looking tire and cost less than other tires mentioned
  6. Oct 9, 2015 at 3:34 PM
    Missouriprerunner
    Missouriprerunner Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    They are not retread tired, what is wrong with running tires with half tread? That's like saying you won't run a tire more than 10,000 miles because they are too dangerous for you below 80 percent tread
  7. Oct 9, 2015 at 4:15 PM
    Schaffer
    Schaffer Well-Known Member
    PA
    2015 Access Cab
    Same here. I have a set on my other truck and my dad has a set on 2 of his rigs. They work well in all conditions and i'll have a set on my Taco when the factory tires wear out.
  8. Oct 9, 2015 at 6:21 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I would never buy duracraps, uh I mean duratracs again. Absolutely horrible experience. Terrible wet traction, simply don't balance, cupping horribly, noisy as fuck. I should have just bolted cinder blocks to the truck.
  9. Oct 9, 2015 at 9:21 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    ^this^
    I'll throw in my vote for the hankooks, great all around tire and their quiet on the hiway.
    For the cost they last a long time,, my buddy run's the E-rated 285's on his dodge 3/4 ton diesel, his first set lasted 75k and still had tread. He went back and bought another set. nuff said.
  10. Oct 9, 2015 at 9:24 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I'm happy with the hankooks,but with that many miles per week you better go with the best road tire you can.
  11. Oct 9, 2015 at 10:17 PM
    nd4spdbh
    SoCal
    The fact that they are the ONLY thing keeping your vehicle sticking to the road, and have been used and DISGARDED by someone else.... no thanks.
    Tires have a shelf life as well even if their tread is still of proper depth.... I might use an old used tire for a spare to get me out of a bind but other than that nope.... 500-800 bucks extra every 40 to 50 FREAKING THOUSAND miles aint worth the peace of mind and my life.
    ace96 likes this.
  12. Oct 9, 2015 at 10:45 PM
    Tacoma005
    Tacoma005 Well-Known Member
    Bellingham, WA
    2005 DCSB TRD Off-Road 4X4
    KMC Crank Rims, 30" Baja Designs light bar, HomerTaco front grill
    I've always liked the Toyo Open Country AT. Great mileage and quiet on the street. Comes with a 65,000 mile warranty.
    IMG_8187.jpg Alwa
  13. Oct 10, 2015 at 6:09 AM
    muslmutt
    muslmutt [OP] Well-Known Member
    SE OK
    2004 SR5 Tacoma Access Cab (Sold), 2015 Tacoma TRD Off Road DCSB
  14. Oct 10, 2015 at 6:18 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Dyna pro atm. Snow flake rated, recessed rim, fairly quiet, smooth, and great traction. $615 otd at Discount tire for the P-metrics 265/75.
    Tarzan13 likes this.
  15. Oct 10, 2015 at 6:24 AM
    #35
    muslmutt
    SE OK
    I notice some of the tires I am looking at have a speed rating of about 37 mph, and others have over 100 mph. Where am I going to see the difference? Does not seem like a tire with a speed rating of 37 mph is going to be what I want. I also notice that a lot of these tires have a damage/defect warranty instead of a mileage warranty. Thinking I want a mileage warranty. Right?
  16. Oct 10, 2015 at 7:13 AM
    #36
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    Michelin Defender LTX are quite nice. Not super aggressive but a good all season tire that wears very well and is pretty quiet.
  17. Oct 10, 2015 at 7:24 AM
    #37
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    If you do any offroad or snow driving I would NOT get a highway tire. I drive 100 miles a day mostly highway. On my first 05 I ditched the stock tires at about 5k miles. They were dangerous in the snow. Put Michelin highway tires on it and they were smooth, quiet, and only slightly better in the snow regardless of being M&S rated. Damn things wouldn't wear out though so finally about 70k miles later I put Grabber AT2's on it. Couldn't have been happier. Sold the truck 30k miles later and they still looked brand new. But they are a heavy tire though and I did lose 1.5MPG. That truck's long gone but when I put wheels and tires on my current truck 3 years ago I got talked into General Grabber HTS' by my tire rack rep. Smooth and quiet on the highway but after 35k they are almost at the wear bars and since about 10k miles they have SUCKED in the snow. And I can barely drive on my grass in my yard without using 4wd if it's even remotely wet. I'll be buying tires soon and I'm currently thinking of either another set of the Grabber AT2's, the Hankook ATM's, or maybe the new Kumho KL51's. The Kumho's are ridiculously cheap with the current rebate and they are severe snow rated. They aren't terribly heavy either. I would do AT2's in a heartbeat again if it weren't for the weight of them.
  18. Oct 10, 2015 at 7:30 AM
    #38
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Op drives 100 miles a day on pavement. Don't go duratracs. Also these are my Toyo at2's. They have 18k miles and are 2 1/2 yrs old. They are awesome all around tire but................
    Severely on crack!!!!
  19. Oct 10, 2015 at 8:20 AM
    #39
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I agree that with that many highway miles, don't go Duratracs. Very, very noisy.
    For highway, off-road, rain, dry, and snow, the Michelin AT2 is one of the best tires out there. They performed as well as BFG TA KO in snow (and the BFGs were snowflake rated). Never had a tire with better wet/dry traction either. And forest roads (even steep and rocky where 4Lo was required) no issues whatsoever. I swapped them for the Duratracs due to a big sale, but they had 6/32nds and 7/32nds tread remaining after 70k miles. It doesn't get much better than that. Many reviewers on Tire Rack see 100k miles out of them. Traction does decrease though around 70k miles. And didn't get stuck once on the last snow wheelin trip this winter when they were that worn (can't say the same for some others with a lot more tread).
    As for Discoverers, many of us won't make that mistake again. Very poor snow traction. I am interested to hear how the Toyo's do in snow and their longevity, but the cracking above may dispel my desire to try them. I think I'll be going back to the Michelin AT2 when these Duratracs are done.
  20. Oct 10, 2015 at 10:13 AM
    #40
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Well I don't walk in blind folded and walk out with the first 4 tires I can pick up. Used doesn't mean abused. I go in to his shop and ask him has anyone swapped out tires recently and he will show me if they did. Like the last set I had was a set of Michelin off road tires with 80-85 percent tread on them the guy wanted some mud tires so he sold the ones that came with his USED truck to put on some mud tires. So I got a full set of nice tires for under 400 bucks. Call me crazy but that's a good deal. And my current set are Firestone destination A/T's and I put a full set with 80 percent tread (except the rear right was more like 50 lol) on my truck for 180 mounted and balanced.
