Tire & rim selection for 3" lift 4x4
Discussion in 'Wheels & Tires' started by mikef18, Apr 23, 2009.
  1. Apr 23, 2009 at 1:50 PM
    mikef18
    mikef18 [OP] Member
    florida
    2014 tacoma double cab LB
    Hi everyone, new guy here and I've been researching this site to help me select a lift kit and wheels for my 09 Tacoma 4x4 double cab. Wondering if anyone knows if the XD revolver rims 18" x 9" with -12 offset and 4.53 back spacing paired with Nitto Dune Grapplers LT325 60 r18 will fit on my truck with a Toytec 3" ultimate lift kit w/ AAL for TSB. I'm mostly driving on road and tow a boat alot but like the off-road capability when needed. Are the tires going to be too wide to clear and are 17' wheels a better choice for any reason.
    Thanks
    LT325/60R18, Nitto Dune Grappler
    • Load Range = E
    • Max Load = 3525
    • Tread Depth = 16/32
    • Overall Diameter = 33.11"
    • Side Wall = Black Letters
    XD Revolver 18x9 -12mm 4.53 BS
  2. Apr 23, 2009 at 4:35 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    325 is way to big for 17's or 18's, go with 275 or 285's. i would go with 17's because the tire will be cheaper.
  3. Apr 23, 2009 at 4:35 PM
    bajamoon
    STEVE
    Whittier
    you are too.
  4. Apr 23, 2009 at 11:12 PM
    bjamison01
    bjamison01 Member
    Brent
    Sacramento, CA
    09 Taco DC 4x4 Sport
    Icon C/Os, TC UCAs, Rear Billie 5100's, Toytec AAL, Shim, Moto Metal 955's (machined), Nitto TGs 285/70/17.
    I'm also in the process of purchasing/installing a toytec ultimate lift and will be going with 18x9 rims (though I'm going with moto metal 957's).
    After a whole lot of research - I've decided on Nitto TG's in a 275/65/18 size. Works out to be about 32.07" and should allow me to keep the mud flaps and avoid trimming. However, I won't really know until I get everything on.
    That's my 2 cents.
  5. Apr 23, 2009 at 11:45 PM
    Ragin
    Ragin Well-Known Member
    Lafayette, Louisiana
    07 4x4 SR5 TRD
    3inch Skyjacker front struts, Skyjacker hydro7000 rear shocks w/ AAL, K&N CAI, Instrument Cluster Mod, GrillCraft Mesh Grill w/ Pro Comp 9556 5" fog lights, fog light mod, Wet Okole Seat Covers, Remote Start, BHLM, Diamond D3 10", Twister F2 190 Amp,
    325 is way too big, I have a 3" lift and I put 285/70/17's and I had to trim a lil plastic and cut and bend in and weld my body mount subframe shit. But they don't rub so its cool, haha
    it was only on the driver side though for some strange reason
  6. Apr 24, 2009 at 2:54 PM
    mikef18
    mikef18 [OP] Member
    florida
    thanks for the feedback guys!
  7. May 22, 2012 at 7:05 PM
    beauxxbennett
    beauxxbennett Active Member
    Beau
    Currituck
    06 Tacoma
    Aries bull bar, PA system, aftermarket head unit, and JL stealthbox.
    What did you wind up going with on tire size? I'm shopping around now. I'm looking to clear 33x12.5
  8. May 25, 2012 at 6:47 AM
    DevL
    DevL Well-Known Member
    If your definition of "clearing" is not rubbing on the street most of the time and ru bing lots offroad... 33x12.5 can clear.
    If you definition of clearing is not rubbing 33x12.5" will not fit. It will be especially bad at full lock with aftermarket upper control arms. Also be prepared for a drop in mpg of about 25%.
