Tire Rotation Q
Discussion in 'Wheels & Tires' started by Santiago, Aug 15, 2007.
  1. Aug 15, 2007 at 2:10 PM
    Santiago
    Santiago [OP] New Member
    '99 PreRunner TRD
    First time rotating my tires on a '99 two-wheel drive PreRunner. Any suggestions/special instructions/warnings I should know about?
    left back tire --> right front tire
    right back tire --> left front tire
    Thanks in advance
  2. Aug 15, 2007 at 2:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can criss-cross if you want to, but it isnt really all that necessary. front to back should be fine. and dont forget to torque your lugnuts to specs.
  3. Aug 15, 2007 at 2:43 PM
    Santiago
    '99 PreRunner TRD
    Thank you TacoMan06...but torquing my lugnuts to spec are waaay out of my reach, no clue on how to do this here...i thought "tight enough" was sufficient.
  4. Aug 15, 2007 at 3:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it will more than likely be ok to get them "tight enough", but torquing the lugnuts ensures that everything is even, and it also will keep the lugs from stripping or breaking. all you gotta do is get a half inch torque wrench from autozone($25), set it to what your specs are, which is, and im guessing around 85ft/lbs, and tighten them up snug, then use the torque wrench to set them. turn the wrench until it "clicks", and you are set. by the way, welcome to tw, santiago!!!
  5. Aug 16, 2007 at 8:49 AM
    Santiago
    '99 PreRunner TRD
    I appreciate your help here...i'll look into purchasing the type of wrench you mentioned.
    and thanks for the welcome greeting as well...
  6. Aug 16, 2007 at 1:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    let me know how it turns out man!!
  7. Aug 16, 2007 at 3:22 PM
    topdec
    topdec Well-Known Member
    Its also not a bad idea to tighten the lugs in a star pattern.
  8. Aug 16, 2007 at 5:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    great point topdec:)!!! i forgot to mention that!!! tightening in a star pattern helps keep torque on the lugs even also!!
