Tire rub fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by Desiel, Jul 20, 2011.
  1. Jul 20, 2011 at 3:13 PM
    Desiel
    Desiel [OP] Well-Known Member
    Kyle
    Morristown, TN
    01 Tacoma XtraCab SR5 4x4
    So far: Tint American Racing Wheels with 265/75-15
    So would you folks suggest trimming on the inner fender or spacing out the wheels a bit?
    It only rubs 80% and up turned to the left, not a huge deal right now but I have a feeling when I get new rubber it will be.
  2. Jul 20, 2011 at 3:44 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Where is it rubbing? What size tire/wheel are you running? Lift?
    I have a 3" suspension lift and have 33x12.50 tires. It was rubbing the frame and fender slightly. I added 1" spacers which solved the frame problem, but it rubbed the fenders even worse than before. There was then lots of trimming of plastic and massaging of the pinch weld area with a sledge hammer. All is good now I think.:D
  3. Jul 20, 2011 at 4:34 PM
    Desiel
    Kyle
    Morristown, TN
    Stock... running 265/75-15
    It only rubs the plastic that is inside the fender, I have a feeling when I put some tires on with more meat it will be worse.
  4. Jul 21, 2011 at 3:35 PM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    I've got 285/75-16s on American Racing rims and a 3" lift and have no problems with rubbing. Put a little lift on it. You can buy the coil spacer lifts pretty cheap and most diy's can get it done in a few hours.
  5. Jul 21, 2011 at 3:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If it only rubs the plastic, then just trim. When you hit the frame rail then you need spacers
