Tire sealant?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, Feb 10, 2012.
  1. Feb 10, 2012 at 9:11 AM
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    4Wheel Parts hold music is Tool- 46 and 2....I shit you not
  2. Feb 10, 2012 at 9:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That's the first good thing I've heard about 4wp in a long time :laugh:
  3. Feb 10, 2012 at 6:10 PM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    I was just at the store tonight at saw Slime that said it was TPMS friendly. But even so, Slime and Fix-A-Flat create a chemical reaction with air. That reaction does not stop when the tire is sealed up, it will continue to eat away at the tire until it's cleaned out. And the guy who has to clean it will probably think of nothing but murder while he does it.
    So it's good to get you out of an emergency situation, but don't leave it in the tire long, and consider a tip for the guy who has to clean it up, perhaps.
  4. Feb 10, 2012 at 10:40 PM
    clobato
    clobato Member
    Westminster, CO
    Replace the tire ASAP!!!!! Any tire shop worth anything will NEVER repair any hole that is in the shoulder or side wall. A hole in the side wall significantly reduces the integrity of the tire and is a safety hazard.
    I worked at Discount Tire Company for 6 years. We'd never repair a side wall puncture, and wouldn't have let the vehicle leave with the tire still on the vehicle. At a minimum the spare tire would have been put on until a new tire could be ordered. Also, don't use the fix a flat shit! It eats away the interior liner of the tire. If we found fix a flat in a tire, we couldn't repair it.
  5. Feb 11, 2012 at 5:49 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Fix a flat and slime shit is for the missus that can't or won't change a tire, in that case I would prefer my girls to have fix a flat on board for an emergency in a spooky place and deal with the mess later, but somehow, they always end up calling me to go and bail them from the flat so it's useless IMO.
    Also I used fix a flat a long time ago and it never came off completely from the rim even with a wire brush on a drill and after a few tires on the same rim, it was harder to seal the bead with the residue, avoid that crap at all cost.
    And I wouldn't expose my expensive sensors to that crap even if it says it's "friendly" to them, are you willing to risk a $300.00+ sensor on some advertising?, not me for sure...........
  6. Feb 11, 2012 at 6:01 AM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Like others have said. You need a new tire. If you do use a tire sealant make sure you tell the tire guy before he breaks the tire down. That stuff is messy and smells like shit when you break it down.
  7. Feb 11, 2012 at 6:02 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
  8. Feb 11, 2012 at 7:15 AM
    Pugga
    Massachusetts
    Fix a flat and slime are completely different products and have different uses. Fix a flat is an emergency flat repair and will seal a hole and inflate the tire. Slime will not inflate the tire and is great for ATVs, UTVs and dirt bikes where you could constantly be running over nails and screws. The slime seals the hole so you don't get a flat in the first place. It actually works really well, just sucks when you have to change the tire. I wouldn't put it in a wheel that has a sensor in it but to say it's just for the Mrs is pretty ignorant in my opinion...
  9. Feb 11, 2012 at 9:08 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    The sensor I believe would go bad I read somewhere depending on the type there could be a tiny hole in the sensor for sampling pressure when the system calls for it. Think I would put in on the rear also just in case.
  10. Feb 11, 2012 at 9:16 AM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    I've used the following for years:
    http://www.notubes.com/Sealant-C14.aspx
    Both mountain bike tires and automobile tires. NEVER had a tire eaten away and seals like a champ.
    Also, it dissolves in about 6 months or so leaving nothing behind.
  11. Feb 11, 2012 at 10:01 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I disagree on needing a new tire.
    Especially in this case with the size of the hole you likely damaged NO belts so the risk of a blow out is much lower than a cut or tear in the sidewall being repaired.
  12. Feb 11, 2012 at 1:19 PM
    Mandy3206
    San Juan PR
    I know that fix a flat inflates and seals and slime just runs inside the tire, I mean that the mess is the same with both products.
    If you like them, good for you, but not for me.
    Also maybe I wasn't clear about it, but I meant Fix A Flat was for the missus to use in an emergency in a spooky area and dealing with the mess later may include anything from cleaning the rim to buy a new wheel and sensor if it gets damaged. The slime is to prevent flats, or to fix some failures, but still need to inflate the tire, so not a good remedy for the missus in distress.
    Slime may be good for other uses and/or applications, but for a road vehicle sucks IMO.
  13. Mar 15, 2012 at 6:06 PM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Op, what did you decide on?
  14. Mar 15, 2012 at 7:34 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's a mess and it will destroy aluminum wheels.
    It will also be a big problem for your TPMS if you have them.
  15. Mar 15, 2012 at 7:41 PM
    #35
    jandrews
    '09 FourDubDee TRD OR
    Just put your spare on and use the questionable tire as your spare. Easy.
  16. Mar 15, 2012 at 7:50 PM
    #36
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    That stuff will damage the tpms sensors. I wouldn't use it unless it was your only option.
  17. Mar 15, 2012 at 10:11 PM
    #37
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    Exactly, have them switched, patch the pin hole one before mounting on your spare steel wheel. Round trip $50. Don't keep driving on it, especially as we go from winter to summer. Having a tire go down unexpectedly is not nearly as fun as having a hot chick go down unexpectedly.
  18. Mar 15, 2012 at 11:42 PM
    #38
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    I. Fucking. Hate. Slime. I will charge customers extra if I have to pull one off, and I won't put it back on. Use that shit = new tire in my books. And extra time to clean the rim. :rant: Patching a sidewall isn't the best thing, and will be hard to find someone who will. Contact the manufacture before you go destroy the warranty with a bad repair.
  19. Mar 15, 2012 at 11:57 PM
    #39
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    i work at a bike shop as a mechanic and i HATE slime, slime tubes and slime tubeless sealent.. it creates a huge mess and is a nightmare to clean. and thats on a bike tire! i couldnt imagine a car tire! i say new tire, just on the safe side, or keep filling it untill you need new tires:notsure:
  20. Mar 16, 2012 at 7:13 AM
    #40
    KyleJ600
    KyleJ600 Active Member
    Kyle
    Columbus ga
    Prerunner TRD sport
    I would plug it. I ran a set of 37s with a plug in sidewall. Sounds kinda crazy but it worked with no problem.
