Tire sensor question. Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spitdog, Oct 8, 2014.
  1. Oct 8, 2014 at 9:28 AM
    spitdog
    spitdog [OP] Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Can I replace my tire sensors with regular scharder valves? I'm clueless about this and just need a little help. Thanks
  2. Oct 8, 2014 at 9:29 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Read a guy that removed them, put them in a plastic bag and placed the bag in his glovebox. I assume the dash light would still be on though.
  3. Oct 8, 2014 at 9:31 AM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    Yes.
    Tire pressure light will be on.
  4. Oct 8, 2014 at 9:41 AM
    spitdog
    Thank you guys for the quick response. I new that I would have to deal with the dash light. Just didn't know about the hole where the sensons go In the rim versus regular scharder valves hole. I guess they are the same size.
    thanks so much.
  5. Oct 8, 2014 at 10:04 AM
    2008tacomaowner
    2008tacomaowner Well-Known Member
    Cleveland, TN
    2008 Sr5 4x4
    Bilstien 5100's @ 2.5 up front, 2" add-a-leaf.
  6. Oct 8, 2014 at 10:06 AM
    Manwithoutaplan
    ID
    I had my my tire sensor stolen with my rims/tires. So i had a Jerez remove the Led light so i am good to go :D.
  7. Oct 8, 2014 at 10:14 AM
    2008tacomaowner
    Cleveland, TN
    2008 Sr5 4x4
    I thought about remind tn the light. But, the link I posted was way easier than taking the cluster apart to get to the light. Also give you the option of easily reversing the process of you ever decide to put sensors back in.
  8. Oct 8, 2014 at 10:15 AM
    Manwithoutaplan
    ID
    can you post the link to check it out? ^
  9. Oct 8, 2014 at 10:17 AM
    spitdog
  10. Oct 8, 2014 at 11:41 AM
    2008tacomaowner
    Cleveland, TN
    2008 Sr5 4x4
    Links up. In post #5. Really simple takes longer to get the bolts out for the radio that to do the mod.
  11. Oct 8, 2014 at 11:46 AM
    Manwithoutaplan
    ID
    very cool.
    I figured since mine where gone, i was not going to buy another set. I know when my tires look low.
