Tire Size Calculator add Gear change
Discussion in 'Site Suggestions' started by tostidos, Feb 10, 2013.
  1. Feb 10, 2013 at 5:25 PM
    tostidos
    tostidos [OP] Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    OK now I know there is the little bar on the bottom of the calculator that tells you your RPM @ 65mph depending on what gear ratio you are running. But what about being able to manually select which gear ratio you want to run to see dif in MPH in the list thats already provided? say stock vs 315/70R17 and 4.56 gears or vs 315/70R17 and 4.88 gears? I think this would help people choose a proper gear ratio. Now is this even a calculator the greats minds of TW came up with or simply borrowed from another source?
    If this has been brought up before then carry on!
    Thoughts?
  2. Feb 11, 2013 at 9:51 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
  3. Feb 14, 2013 at 9:14 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    bumpity bump bump
  4. Feb 15, 2013 at 12:02 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
  5. Apr 7, 2013 at 8:08 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    sounds like a good idea. Bump
