Tire size for 3 inch lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by TritonBass, Jan 10, 2011.
  1. Jan 10, 2011 at 6:37 PM
    TritonBass
    TritonBass [OP] Member
    Taylor
    Chattanooga, TN
    2011 Tacoma SR5 TRD 4X4 (Metallic Gray)
    I just ordered the ToyTec ultimate lift with the 5100s in front and 5150s in rear with AAL. If i set the 5100s at 3", what size tire should i run? also would u guys suggest running toyota factory wheels or aftermarket? i dont really want my tires to stick out real wide. I posted a thread on here trying to figure out what lift i wanted to go with and it really helped me. now i am trying to decide on the tire/wheel combo. can you use an aftermarket wheel wihtout having your tires stick out too wide?
  2. Jan 10, 2011 at 8:42 PM
    TritonBass
    Taylor
    Chattanooga, TN
    any suggestions? i would like the best possible offroad performance.
  3. Jan 10, 2011 at 8:51 PM
    rcfreak201
    rcfreak201 Well-Known Member
    go with 285/75/16s, it doesnt really stick out at all, i have that size tire, Toyo Open Country ATs with pro comp xtreme alloy serious 7089s in flat black
    oh and a 2.5 front spacer and stock rear
  4. Jan 10, 2011 at 10:29 PM
    TritonBass
    Taylor
    Chattanooga, TN
    What's better for offroad capabilities- 265/75R16 or 285/75R16?
  5. Jan 11, 2011 at 6:39 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    I would think the 285s would be better because they are wider. If you have 15" rims I would recommend 32s, I would not go to 33/12.5s because you will have to trim a lot off your truck.
