Tire Size on 4cyl - NOT PRE-RUNNER
Discussion in 'Wheels & Tires' started by thehtizzle@gmail.com, Jun 20, 2008.
  1. Jun 20, 2008 at 5:43 AM
    thehtizzle@gmail.com [OP] Well-Known Member
    Houston, TX
    06 Tacoma 4cyl Access Cab
    3" Redy Lift, radio upgrade, sub + amp, window visors
    I just bought a 2006 Tacoma I-4 Access Cab with 35,000m. It has the 215/70 15 on it. I was looking to either upgrade tires to the 245/70 17 or go with a more low-profile look of a 255/50 18. When I went to discount tire, they said that the truck is front wheel drive? Does anyone know if this is true? What is the largest tire you have fit under the truck? I think I am leaning towards going with a higher ride than the low-profile. If I get a body lift, would this allow for taller tires?
  2. Jun 20, 2008 at 5:48 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    LOL, it's not FWD, tell the m0r0n that's it's a friggin truck. If you want a higher ride, get a lift kit. Personally I would run OEM type tires
  3. Jun 20, 2008 at 6:07 AM
    Houston, TX
    I didn't think so, but I have never owned a 4cyl truck before. My first vehicle was a 1997 T-100 4x4 and I finally made the decision to downgrade to a smaller truck while I do a lot of city driving. I really miss the ride height of the T-100 and want to get some of that back with the larger tires. Any idea on how much a lift kit cost for a Tacoma like mine?
  4. Jun 20, 2008 at 6:13 AM
    klown
    Lynchburg, VA
    I don't personally know, but there are a bunch of threads on here that talk about it. It is one of the popular mods for the taco. Type "lift kit" in the search field and I'm sure you'll find more info then you will know what to do with.
    Good luck man, hope you enjoy your truck!
  5. Jun 20, 2008 at 6:29 AM
    Houston, TX
    Anyone else have any experience/suggestions on upgrading a truck like this? Some pictures would be awesome too
  6. Jun 20, 2008 at 6:38 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    :rofl: Run. There has never been a front wheel drive Toyota truck. If that place is so badly informed about your truck I wouldn't trust them for advice on tires.
  7. Jun 20, 2008 at 6:13 PM
    Mudbug
    Mudbug Well-Known Member
    Amsoil 0w-20 engine oil and Amsoil Full synthetic 75w-90 in the Transmission, transfer case, front and rear Differentials. AFE Cold Air Intake
    If its fwd....IT'S NOT A FREAKIN TRUCK!
    Yes that means that the honda ridgeline is in fact a minivan on stilts with a bed!
  8. Jun 21, 2008 at 1:56 PM
    jb9281
    jb9281 Active Member
    North Carolina
    07 Access Cab SR5
    15" Borbett Alloy Wheels, Chrome tool box, Door lock beeper mod, AFE Dry air filter, HD Radio,
    No, the truck is not a front wheel drive, but it takes a front wheel drive rim with the the 40 degree offset to fit this truck.
    I installed some 17" Rav 4 factory alloy wheels on my truck which is a 2007 4 cylinder access cab truck. The truck ran fine with these wheels ,but my gas milage went from 24 to 19 mpg. I took these wheels off and ordered a set of Borlla 15" alloy wheels from the Tirerack that that looked almost like the Rav 4 wheels and my mpg came back to normal
  9. Jun 21, 2008 at 4:08 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Read with interest the above post because on my old Accord, it went from about 30MPG to 27 when I went from 15" to 17" wheels and tires.
    I want to upgrade my 5 lug 15" wheels to 16", but dont want the big fuel hit. Has anyone gone to 16" with 235/60 -16 tires, which is the correct size tire for the same diameter. And what were your results. The Taco is great but at times it feels very insecure over rippled pavement and breaks in the roads with the 15" wheels.
    TIA Dan
  10. Jun 21, 2008 at 4:57 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Just be moderate with the tire size; go either 1-1.5" taller or so and not so wide they hang out of the fenders, and also remember you should have a 3.31 or 3.58 diff ratio (what trans?). Usually increasing tire size ~1" +/- will correct speedo error, and you will be traveling 3.5-5 % or so more than shown on the ODO, so take that into consideration with mileage checks. I have always thought the 5 lug trucks have to small a tire that doesn't even begin to fill up the wheelwells, a 225/75-15 should have been the minimum along with a corresponding increase in axle ratio's ever since the 05 new body style was introduced. 235/60-16 should be ok, if it were me though, I would use a 225/70-16 to get a little height. Someone on here, or TS has a 5 lug with Toyota 16" aloys off either a Camry, or the mini-van, and it looks good.
  11. Jun 21, 2008 at 5:38 PM
    91r100gs
    Dan
    Kansas City area
    I have read that thread and the OP stated that it made the truck more secure feeling, but made no mention if his mileage was affected with that combo. He used the P235/60-16 tires. Those wheels are available on Ebay from a Toyota dealer for about $640 shipped. I search Ebay often hoping to find a takeoff set for 4 bills or so. They are from a Camry. My truck is getting 27 MPG and with $4 fuel and still rising, I need to preserve that mileage. Thanks for your reply and suggestions.
    Dan
  12. Jun 21, 2008 at 6:38 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    I think as long as you don't change the overall circumference, you should get the samr gas mileage if you go with a bigger rim. Changing the rim size and getting larger tires also affects the final drive ratio.
  13. Jun 22, 2008 at 6:27 PM
    RobPaul
    RobPaul Choose Goodness. Have Discretion.
    Rob
    Northern California
    2016 TRD Sport
    Interesting thread - and I have had a similar reduction in mileage.
    I have run about 3 tanks full of gas through the truck since I upgraded my 5-lug steel wheels for a set of (nearly new) X-Runner 18" Toyota wheels with Bridgestone Potenza RE050 tires. These wheels have virtually the exact outside diameter as the stock steelies - as calculated by the website. 26.9 inches orig, versus 27.0 inches after.
    Mileage before the change 23.0-24.0 MPG.
    Mileage after the change 20.7 - 21.2 MPG.
    So it looks like a hit of about 10% off the old set. I am supposing it is because the new tires have such amazing grip - they must "grab the road" more. The others were so crappy and slippery - they must have glided obove the pavement.
    In the end - I would still do it over! The handling on the turns is SO superior it is unfathomable that I would tolerate the old ones again. And if they save my bacon during any future emergency move in the rainy season - then what the heck - well worth the mileage penalty.
    Rob
  14. Jun 22, 2008 at 7:24 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    That is what I call a BIG hit, same height tire on a light alloy wheel; the 15x6 steelie probably weighs very close to the larger alloy. That 10% is a lot for just additional rolling resistance, are you sure winter gas blends didn't have anything to do with it, or ethanol in the fuel? You have had the tires/wheels on for a while haven't you? I would think that swap would be tit for tat, or maybe 1-2% for additional rolling resistance.
    EDIT: My bad; even after I read about the wheels being the X-Runner setup, I still thought you were the person who put the Camry wheels on his 5 lug Tacoma. The Camry wheels are probably only 16" x 6 or maybe 17"'s but probably not sport tires. But; I still think 10% seems a little excessive, even for the X Runner stuff.
