Tire size question
Discussion in 'Wheels & Tires' started by BigBiscuit, Aug 20, 2011.
  1. Aug 20, 2011 at 8:03 PM
    BigBiscuit
    BigBiscuit [OP] Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    I have a '10 DCSB TRD Sport with the rear TSB springs done and ToyTec Coilovers on the front set at 1.75". Right now I'm still running the stock tires and wheels but I'm wanting to go up in size on the tires. The first obvious choice is a 265/70/17 but I'd like something a bit larger. Anybody running 275/70/17 tires with this same lift? I'll be staying with stock wheels for now. I'm hoping that the rubbing would be minimum and possible be taken care of with wheel spacers. I looked at some 255/75/17 which would be an option, but I like the wider aspect/height ratio of the 275's better.
    Thanks gents.
  2. Aug 21, 2011 at 9:00 AM
    BigBiscuit
    Mass.
    Hmmmmm. No love here. I guess I should ask mundane questions like what color rim goes best with MGM or something to that effect and this thread would go 20 pages at least. :confused:
  3. Sep 24, 2011 at 6:39 AM
    Inacoma
    Inacoma Member
    thomas
    Western N.C
    07 DC TRD sport
    Bone Stock (for now)
    lol, I am trying to get the same question answered....i found this using the search function....I guess I will be flamed for asking it again. LOL
  4. Sep 24, 2011 at 6:52 AM
    FLtaco
    FLtaco Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    Not 100% but my moms boyfriend has a 06 with 285r17 which is 33" tire I believe but he has some 3" spacer lift. So from sounds of it a 275 would work but if you didn't mind a little trimming of plastic a 285 could fit probably. Cab mount chop will be determined after you take it offroad. Again sorry I don't have better answer. Just kinda beat around a bush. Hope it helps though
  5. Sep 24, 2011 at 7:11 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    With no lift, 275's or 285's will be pretty tight. There have been folks on here that fit 285's with no lift, but if you even plan to go over some speedbumps, you have no room for it. I suggest staying with 265's or getting a lift with 275's/285's.
    Hope this helps, and by no means am I an expert on this stuff, just wait for some of the more experienced guys to get on here.
    -- Matt --
  6. Sep 24, 2011 at 7:16 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    I believe he has 1.75 up front and rear tsb
  7. Sep 24, 2011 at 8:09 AM
    CanisLupus
    Stokesdale | NC
    I would think 275's would be fine then but I'd try and look around for people who have done this.
    Good luck,
    -- Matt --
  8. Sep 24, 2011 at 9:48 AM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Agree someone probably has identical set up on here. And more accurate info than I. Those are just guesstemations.
  9. Sep 24, 2011 at 10:03 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    or you could search for this question that has been answered 100000 times
  10. Sep 24, 2011 at 10:49 AM
    BigBiscuit
    Mass.
    I did. So maybe you can show me the answer in a search because I surely didn't find it. :bored:
    Don't bother. I just ordered a set of 255/75/17's
  11. Sep 24, 2011 at 11:02 AM
    pudge151
    Sean
    Connecticut
  12. Sep 24, 2011 at 11:27 AM
    BigBiscuit
    Mass.
    I know about the tire size calculator quite well. It doesn't answer the question. The calculator doesn't know if the tires you choose are going to rub on mud flaps, UCA's or whatever.
  13. Sep 24, 2011 at 11:37 AM
    pudge151
    Sean
    Connecticut
    from what i have learned on here. the biggest you can go is 265/70/17 on anything with less than 3" of lift, any bigger and it will rub something or you will need to trim
  14. Sep 24, 2011 at 11:41 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You can run 255/80/17 with a 2.5" lift
  15. Sep 24, 2011 at 11:54 AM
    BigBiscuit
    Mass.
    Yeah. And I saw the other post here from yesterday regarding that size tire. I only have the front sett at 1.75". I know the other guy went with the 255/80/17 with the same amount of lift, but you're even more limited to the tire selections available in that size. I did a lot of careful measuring and I'm comfortable with the 255/75/17's I just ordered. I went with the Bridgestone Dueler AT Revo 2.
    Contrary to "some" peoples opinions, I researched it here quite extensively before asking. Never got any answers so i went with my gut feeling on the 255/75/17
  16. Sep 24, 2011 at 12:17 PM
    pudge151
    Sean
    Connecticut
    so you can go taller but they need to be skinnier? i guess that does make sense. i think most trucks looks better like that anyway, more like the old landcruisers did. plus the skinnier tires are better in mud and snow
  17. Sep 24, 2011 at 12:20 PM
    BigBiscuit
    Mass.
    Exactly. Otherwise you need wheel spacers like Spidertrax or something. The 255's are only 3/8" narrower. Sometime take a look at your UCA and it's relation to the tire width and you'll see what I'm talking about.
  18. Sep 24, 2011 at 12:21 PM
    pudge151
    Sean
    Connecticut
    yeah i like the way most trucks look when the tires dont stick way out, prob better gas mileage too.
  19. Sep 24, 2011 at 12:21 PM
    BigBiscuit
    Mass.
    And just for the record, I'm installing Spidertrax 1.25" spacers regardless. I like the look of the wheels pushed outwards anyways so it'll just give me that much more clearance.
  20. Sep 24, 2011 at 12:24 PM
    BigBiscuit
    Mass.
    Yeah, the narrower tires don't tend to cut into your gas mileage like the wider tires do.
