Tire size with bilstien 1500 set at 2.5"
Discussion in 'Wheels & Tires' started by Jm1hawk, Aug 20, 2010.
  1. Aug 20, 2010 at 7:34 PM
    Jm1hawk
    Jm1hawk [OP] Well-Known Member
    Jamie
    Irvine
    05 4x4 black
    OME885s MT 17 inch powdercoated rims BHLM 20% tint Alpine headunit Hifonics 1600 W mono amp 2 10" alpine type R subwoofers
    What are the biggest tires i can fit with bilstien 1500 set at 2.5" without rubbing?
  2. Aug 20, 2010 at 7:37 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    265/75 16 or 235/85 16
    265/70 17
    basically any 32" diameter tire 12" or narrower
    or 33" tire with wheel spacer and UCAs and maybe some small trimming
  3. Aug 20, 2010 at 7:38 PM
    Yoytoda
    Roland
    completely stock
    FYI there is a search key. there are loads of info here. Welcome to TW.
  4. Aug 20, 2010 at 10:56 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  5. Aug 21, 2010 at 7:05 AM
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    ^ This link sorta confused me - I am running 5100's set at 2.5 with stock 17" sport rims. Most people on the link talked about 16" rims or suggested 285's with spacers and rub issues. Not many talked about 17" rims. Its sounding more like 265/70/17 are the biggest without rub issues and cutting or trimming.
  6. Aug 21, 2010 at 7:10 AM
    tony92629
    Tony
    Dana Point
    Dont all 2010's TRD's come with 17" rimes? I have been looking for tires myself and I would rather not cut or trim my 2010 DC. The debate is endless and most either talk about 16" rims or adding 285 and adding spacers, cut and trim. I am thinking that the 265/70/17 with a All-Terrain's or Mud tire will look the best without rub issues or cutting. Feedback is always appreciated.
  7. Aug 21, 2010 at 11:21 AM
    Yoytoda
    Roland
    completely stock
    rim size 17 or 16 does not effect the rubbing. a 265/75 16 and 265/70 17 are same dimensions and as long as they are both stock rims they have same backspacing. So whether or not its a 16 or 17 stock rim, if you put 285 wide you need spacers and ucas.
    trd sports have 17s trd Offroad have 16s
