tire size with leveling kit
Discussion in 'Wheels & Tires' started by colinb17, Oct 27, 2009.
  1. Oct 27, 2009 at 7:15 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    hey everyone, i will be in the market for some new tires very soon. i have an 07 sport. i was wondering if with something as minor as a leveling kit or 5100s up front would allow me to run a larger tire than stock. i don't mind some trimming. so pretty much, the same question as everyone else is trying to find the answer to, what is the biggist tire i can run without an actual 3 inch lift?
  2. Oct 27, 2009 at 7:40 PM
    tacoterra
    tacoterra Batang SMB
    South NJ
    11 T4runner TE
    I changed mine from 265/65/17 with stock rims to 265/70/17 DC1s 17x9,4.5 backspace and -12 offset and got away with it with 5100s at 175 and tsb rear.handles better IMO than when i first drove my taco out of the dealer lot.
  3. Oct 27, 2009 at 7:46 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    did you have to do any trimming up front?
  4. Oct 27, 2009 at 7:54 PM
    dragon
    dragon Well-Known Member
    Calgary
    08 AW DC LB 4x4
    a bit of show & go
    I'm running 265/70r17 tires on the stock trd rims with no rubbing on the stock 4x4 suspension.
  5. Oct 27, 2009 at 8:00 PM
    yfz450ak
    yfz450ak Active Member
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    I put a 2.5 daystar strut space and clear 31's no rubbing and no cutting at all... and it sits level,,,
  6. Oct 27, 2009 at 8:07 PM
    tacoterra
    South NJ
    11 T4runner TE
    I did trim a bit since i got the tires before i did the lift.Very minimal trimming.It only rubs on inclined turns before i did the billys.After the lift i got space to put pro-fit mudflaps w/o rubbing.
  7. Oct 27, 2009 at 9:00 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thanks for the feedback. i guess i'll be looking for some 265/70s then. i'll probably do the level too even though it doesn't need it. i just like the look.
  8. Oct 28, 2009 at 7:29 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    With 5100's up front set at 2.5/top most notch you can fit 285/33 tires. You WILL have to trim. Click ME that is a link to what i had trimmed up. Since then i have trimmed more and have gotten my cab mounts chopped and boxed.
    You can run 265/70/17 with no problems.
  9. Oct 28, 2009 at 7:32 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    if i run the billies up front set at max height, will the front of the truck be severly higher than the rear?
    and by 285s, are you talking about 285/70s?
  10. Oct 28, 2009 at 7:39 AM
    Padilla1880
    Daniel
    Temecula, CA
    You will have a slight rake front to rear. An AAL can fix that. Yes 285/70/17 with 5100's set at max/2.5/top most notch.
  11. Oct 28, 2009 at 7:43 AM
    4ari trd
    4ari trd Well-Known Member
    portland, oregon
    08 trd sport double cab long bed
    cat back magnaflow exhaust- stage 2 k&n intake- URD MAF Sensor Calibrator, Westin bull bar, black housing headlights, yellow fogs, 10000k hid, fog light mod, 3in tuff country lift
    My buddy on his trd sport just put a 1.5 inch lift in the front and has 285-70-17 hancook mt on a stock rim and he doesnt rub
  12. Oct 28, 2009 at 7:51 AM
    Padilla1880
    Daniel
    Temecula, CA
    I know there is one guy on here who was able to put 285's on without a lift no trimming or rubbing, but from my own experience and most others on here trimming WAS involved.
