tire size ?
Discussion in 'Wheels & Tires' started by lynyrd3, Sep 8, 2010.
  1. Sep 10, 2010 at 10:24 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    265/75 R16 is what I roll with. I don't have the stock steel rims, but I believe they are the same dimensions of what I have. If you break it down, you could go a little wider, but you lose a little height, or vice versa.
  2. Sep 10, 2010 at 10:26 AM
    thegreatsam
    thegreatsam Well-Known Member
    Sam
    Vancouver, WA
    06 Double Cab TRD Off-Road
  3. Sep 10, 2010 at 10:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I just ditched the dunlops this year also, you'll be much happier with different tires. Personally, I'm not a fan of Kuhmo, my girlfriend had a lot of issues with hers (I know, one case, but it was with all 4 tires and the same issue so it really turned me off). Check out www.mavistire.com. You can search by tire size, load range, brand, etc. At least it'll show you a lot of options. Personally, I like Coopers.
  4. Sep 10, 2010 at 10:52 AM
    BGrutter
    BGrutter Well-Known Member
    Baron
    Kansas City, MO
    2010 4x4 DCSB TRD OR
    Rear-View Camera Mod, Anti-theft Tailgate, No Mud-Flaps, Diff Breather Mod, Color-matched Mirror/Handle covers, Front Valance mod, Phone/GPS/Camera mount, and Illuminated 4x4 Switch ToyTec Ultimate Lift Light Racing UCAs
    Thanks a ton for posting some pics from the shop. It's good to see what exactly it is that people are referring to when the talk about rubbing. I've seen pics that showed where on the mount you can have rubbing, but never on the UCAs. For some reason, I was thinking it was somewhere down the length of the arm while in full lock. Seeing that it is a full-time rub on the top part of the bracket makes a lot more sense.
    Thanks again.
  5. Sep 10, 2010 at 3:06 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    Glad I could help :D
