Tire weight
Discussion in 'Wheels & Tires' started by danteisme, May 1, 2012.
  1. May 1, 2012 at 11:40 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    since i have a 2.7 taco, adding weight to this truck is always a concern. right now i hav p265 70 16 hankook dynapros on the truck. i forget what the weight difference was between these and stock, but i notice no difference at all in power (or at least not drastic enough for me to notice). mpgs remained roughly the same as well (less than .5 mpg difference). these will need replaced by the end of the year, i'm entertaining the idea of going to the p265 75 16 of the same tire(love these tires). the difference in weight between the 265 70 16 and the 265 75 16 is 2 lbs. think i will notice anything going another 2lbs heavier? in my head, i;m thinking no but i'd like your thoughts.
  2. May 1, 2012 at 1:13 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    The weight won't matter so much as the larger diameter. I upsized to 265/76 16's and downsized back to stock a week later and was amazed at how much power it had.
  3. May 1, 2012 at 1:20 PM
    danteisme
    South Western PA
    interesting. i think its only .5" more diameter than what i'm currently running.
  4. May 1, 2012 at 3:38 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    One of the largest weight changes you can make is when you go from a P-rated tire to something like a Load C,D,E. Most P-rated tires are within 1-2 lbs. of the stock tires which is 37lbs depending on the year and size. Most C-load tires are in the 41-47 lbs. and even heavier for D and E.
  5. May 1, 2012 at 5:27 PM
    danteisme
    South Western PA
    thats why i'm sticking with P rated. i don't do enough heavy off roading, or hauling etc.. to warrant me getting anything but a p rated. which stock tires are you referring to as the 37lb ones?
  6. May 1, 2012 at 5:45 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  7. May 1, 2012 at 5:48 PM
    danteisme
    South Western PA
    ah ok, my truck is a standard cab so it only came with the crap 245 75 16 (i think) tires. i may have weighed a little less stock, but even with the 265 70 16s the difference is negligible.
  8. May 1, 2012 at 6:09 PM
    danteisme
    South Western PA
    when you went from 245 to the 265s did you stay P rated?
  9. May 1, 2012 at 9:25 PM
    KenLyns
    Belly of the Beast
    microsnook likes this.
