Tired of seeing 00 steel wool listed as a safe way to clean glass by our members.
Discussion in 'Detailing' started by misc, Aug 5, 2010.
  1. Nov 12, 2012 at 12:18 PM
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I am sure you are correct.. But I have never noticed any issues with it..
  2. Nov 12, 2012 at 12:25 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    it's simple....you have chip in glass....wax fills chip.....wax is not clear thus it hazes....
    I see you have a 09 so I'm not sure how you couldn't of noticed it filling in your chips.
  3. Nov 12, 2012 at 12:34 PM
    boxxed
    Denver, CO
    09 Off Road
    Maybe I didnt look hard enough.. Now that you brought it to my attention I am sure it will look opaque.. Thank you very much!!
    I was thinking I had very shinny glass.... lol
  4. Nov 12, 2012 at 1:17 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Is the use of clay on windows a good or bad idea? :confused:
  5. Nov 12, 2012 at 1:21 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Clay is fine.
    Not sure that it'll do any good, but it's not going to hurt the glass.
    On paint, you get rail dust and pollutants that embed themselves in the relatively soft surface of the paint. Clay grabs these particles and lifts them out of the paint before they begin to oxidize and discolor the paint (this is the source of the "rusty spots" commonly seen on white vehicles).
    These particles don't embed themselves into the surface of your glass.
  6. Nov 12, 2012 at 1:41 PM
    OffroadToy
    Even what you might think as a soft kitchen pad can be a very bad idea. I used what i thought was a soft pad (a mild scubbing side of a sponge) on the hard water spots of a tinted window of my shell... damaged the hell out of it. Ended up paying a professional glass repair company $100 to fix it. :facepalm:
  7. Nov 20, 2012 at 6:33 AM
    JeanClaude
    JeanClaude Well-Known Member
    East Atlanta
    2009 Tacoma Prerunner
    Clay removes many bonded contaminants, which will/may be on glass no doubt. It's not just about embedded contaminants. Imo, someone should be using ironx before trying to remove rail dust via claybar. Clay bar with bits of rail dust will mar the crap out of paint.
  8. Jan 15, 2013 at 11:50 AM
    XXXX
    sKiP
    05 Prius
  9. Jan 15, 2013 at 12:07 PM
    fejus
    fejus Active Member
    Paul
    Flower Mound TX
    2010 Pementaco. TRD Sport
    ok I am not Trolling SERIOUSLY...
    I am confused.... this thread speaks about OO Steel Wool .. Not OOOO Steel wool. The PDF referenced is no longer attached so I cannot read if it talked about OOOO. I have used OOOO Steel Wool to polish windshields of my cars forever and had no staining on the windshields ever.. Again YEARS(8+) of doing this on my car and my parents cars...
    I read through the thread and found no scientific proof that OOOO Steel wool is bad for glass. OO though that a freeking no brainer... I have Googled and found nothing that says that OOOO Steel Wool can scratch glass, or create these valleys you guys are talking about.
    Please show me this information as I am genuinely interested. Anyone have the PDF saved?
  10. Jan 15, 2013 at 12:18 PM
    XXXX
    sKiP
    05 Prius
    TCbob (founder of site) is member "misc". He took one of my old threads and put it under a new members name so I have no ability to revive the PDF. For any non-believers that STEEL (you know metal) won't scratch glass see here http://www.glasswebsite.com/techcenter/
    http://www.winecellarinnovations.com/glasscleaning.pdf
    Any steel regardless of 00, 000, 0000, 00000, 000000, 000000, 0000000, 00000000000, 00000000000000000000000000000000000000000000 shouldn't be rubbed on glass.
    Would you rub your paint with it? If not don't rub it on glass. And just because you do rub paint with it doesn't mean you should rub glass with it.
  11. Jan 15, 2013 at 12:35 PM
    fejus
    fejus Active Member
    Paul
    Flower Mound TX
    Awesome.. Thank you for those links :D
  12. Mar 27, 2014 at 6:26 PM
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
    bump for comments.
  13. Sep 26, 2014 at 5:34 AM
    XXXX
    sKiP
    05 Prius
    needs another bump I see...
