TIRES FOR 2004 Tacoma Ext Cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by PEI.TACOMA, Feb 27, 2013.
  1. Feb 27, 2013 at 7:06 PM
    PEI.TACOMA
    PEI.TACOMA [OP] Taco Mudder
    Josh
    Prince Edward Island
    04 Tacoma Ext Cab
    Getting as soon as i get cash flow
    i would like to put 35x12.50 R15 mickey thompsons on my tacoma, what would i need for a suspension lift?
  2. Feb 27, 2013 at 7:24 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    Two options:
    A: 3" suspension lift + cutting and tubbing the firewall.
    B: 6" drop bracket lift from Fabtech or the like. You have to cut your front suspension crossmember out I believe.
    Option A will be cheaper/more difficult depending on your skills.
    Option B is more of a street lift, i.e. not really meant for serious wheeling, more for looking cool and fitting large tires.
  3. Feb 27, 2013 at 7:26 PM
    PEI.TACOMA
    Josh
    04 Tacoma Ext Cab
    what do you have to do to cut and tube firewall? we have a 4 inch lift restriction in pei, so id have to do the three
  4. Feb 27, 2013 at 7:27 PM
    PEI.TACOMA
    Josh
    04 Tacoma Ext Cab
    what 33`s could i get without cutting firewall, and with the 3 inch lift?
  5. Feb 27, 2013 at 7:39 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    http://www.trailslesstraveled.com/viewarticle.php?id=63&catid=42
    That link will give you an idea what it will take to run 35's with a minimal lift.
    http://www.tacomaworld.com/forum/1s...-tires-rub-my-fender-285-75-16-02-tacoma.html
    That link has a lot of good information on how to run 33x12.50 / 285/75/16 tires on a 3" or less lift.
    Beyond that, you can use the search button at the top to get more info. These topics have been covered dozens of times on this board, so start searching and start reading. There are many very knowledgeable members on here that have build threads and How-to threads that cover your questions.
    Good luck!
  6. Feb 27, 2013 at 8:30 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    SAS it.
  7. Mar 4, 2013 at 12:52 PM
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
    I run a little over 4 inches on my taco on PEI, never had any problems with any restriction law...
  8. Mar 5, 2013 at 3:54 AM
    PEI.TACOMA
    Josh
    04 Tacoma Ext Cab
    Oh i was just told it was 4.. maybe they were wrong, so if i throw a 4 inch lift, and 33`s ill hace no problems with inspection?
  9. Mar 5, 2013 at 9:34 AM
    Buy1Get1Freee
    PEI
    2001 Tacoma TRD
    I didn't, they didn't even say anything to me about it either. So I bet you will be fine. I run 33 KM2s and they absolutely destroy your gas mileage by the way. :D
  10. Mar 6, 2013 at 3:53 AM
    PEI.TACOMA
    Josh
    04 Tacoma Ext Cab
    What do you get for mgs on island?
  11. Mar 6, 2013 at 5:59 AM
    Buy1Get1Freee
    PEI
    2001 Tacoma TRD
    Around 11 mpg with my v6 with 4.10s. :(
  12. Mar 6, 2013 at 5:51 PM
    PEI.TACOMA
    Josh
    04 Tacoma Ext Cab
    Where do you offroad in PEI?
  13. Mar 7, 2013 at 6:00 AM
    Buy1Get1Freee
    PEI
    2001 Tacoma TRD
    Couple trails around Belfast, and down by the ferry. Nothing to spectacular but better then nothing! :D
