Tires help. Suggestions? .2c?
Discussion in 'Suspension' started by machotaco2012, Jul 24, 2016.
  1. Jul 24, 2016 at 9:28 AM
    machotaco2012
    machotaco2012 [OP] Well-Known Member
    •3” front blocks •2” steel rear blocks •1.25" spidertrax spacers for clearance •285/70/17 (33's) Ko2's •20% tint
    Its time to buy tires. Im looking for some mud grips mainly. Probably run 285/70/17 but may try to fit 305's with a 3 inch front spacer lift. Anybody have recommendations. I do a lot of highway driving but i want good mud performance too. Suggestions? Really worried about tread life. I may end up going with the Ko2's but really looking for something more aggressive. How much more tread life do the bfgoodrich allterrains have over the m/t
  2. Jul 25, 2016 at 12:50 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    If you want mud or off-road tires, then worrying about tread life is sort of counter-productive. Since you are doing a lot of highway driving them maybe search for the quietest mud/off-road tire.
    802coma and geekhouse23 like this.
  3. Jul 25, 2016 at 12:57 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Are you prepared to cut? :sawzall:
  4. Jul 25, 2016 at 2:40 PM
    machotaco2012
    No no prolly just go with 285 or 295's
  5. Jul 25, 2016 at 3:47 PM
    geekhouse23
    Still have to with 285's..
  6. Jul 25, 2016 at 5:01 PM
    machotaco2012
    Not true and i have 1.25 wheel spacers
  7. Jul 25, 2016 at 5:03 PM
    geekhouse23
    I still had to trim some after adding .75 spacers..
  8. Jul 25, 2016 at 5:04 PM
    machotaco2012
    Ok bro..
  9. Jul 25, 2016 at 5:08 PM
    802coma
    802coma Well-Known Member
    Caleb
    NEK & Southern VT (Berkshires occasionally)
    '10 Reg Cab 4x4 MT
    I've had really good luck with my hankook dynapro atm's. My reg cab didn't need any weight during the winter at all (I'm in VT). And they are wearing great, as I do a considerable amount of highway driving as well. With all that being said, I would look into hankook mud terrains. I've been looking at them for when I eventually need new tires.
    https://www.amazon.com/Hankook-DynaPro-RT03-Off-Road-Tire/dp/B004QL69BS
    Hopefully this helps.
