Tires on 20 inch rims???
Discussion in 'Wheels & Tires' started by sajahi, Sep 12, 2007.
  1. Sep 12, 2007 at 6:37 PM
    sajahi
    sajahi [OP] Member
    05 PreRunner Dbl Cab
    Audiobahn 800.1 amplifier Sony 10inch shallow mount sub. 20inch rims.
    Hi, I currently own a 05 dbl cab prerunner and it came with 20 inch rims from the previous owner. And the problem is that I wanted to purchase a 3 inch lift kit that says it could fit 32x11.5 OR 33X10.5. The only problem is that the tires that I found are 285/50/20 and I wanted to know if they are the same size? or am I going to have to go for a bigger lift?
    Oh I forgot to mention that the 285/50/20 are Nitto Terra A/T
  2. Sep 12, 2007 at 6:58 PM
    LQQKatmy06
    LQQKatmy06 Carolina Alliance
    T-VILLE, NC
    06 SR5 V6 DC LB TRD Sport 4x4 AUTO. 3" TOYTEC 885 coils w/AALs, ALL-PRO UCAs, 285/70/17 NITTOs, KMC HOSS in BLACK
    They might vary a little in height, most do from brand to brand. The 285s will have a narrow sidewall and will not protect your wheels when or if you go off-road. The 20" wheel will take up alot of your sidewall.
  3. Sep 12, 2007 at 9:23 PM
    sajahi
    sajahi [OP] Member
    These are the tires I want to get, please take a look.
    http://item.express.ebay.com/_Car-T...Q26Q20AccessoriesQQptdiZ2865QQcmdZExpressItem
    I dont go off-road that often maybe once a month or so. I mostly just go to the beach with the truck and have fun in the sand.(I plan to purchase a quad soon) Oh and I wanted to purchase the lift-kit from Toytec as they seem to have a good reputation with the majority on the forum.
    How am I doing so far? Am I making wise decisions based on my needs? Or is that tire size with the 3 inch lift not going to cut it? I dont want to waste a bunch of money and later on come to the surprise that I messed up something and then everything is wrong.
    Thanx for the great input! I really appreciate it.
  4. Sep 13, 2007 at 1:59 PM
    LQQKatmy06
    T-VILLE, NC
    I think you can get a 4" spindle lift for your truck, that tire is basically the same size as mine but on a 20" wheel.
  5. Sep 13, 2007 at 5:38 PM
    sajahi
    sajahi [OP] Member
    Where can I get the 4'' spindle at? how much do they go for $$?
  6. Sep 13, 2007 at 6:17 PM
    LQQKatmy06
    T-VILLE, NC
    alliedoffroad
