Tires screeching while stopping ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwntwnall4u, Feb 15, 2010.
  1. Feb 15, 2010 at 1:12 AM
    dwntwnall4u
    dwntwnall4u [OP] Well-Known Member
    Kevin
    san diego
    2013 4x4 Dbl cab Auto
    I've noticed lately once in a while it sounds like my tires are screeching when I am comming to a stop. But I'm not slamming the brakes at all. What could this be from? I also notice sometimes on turns in parking or neighborhood they seem to screech too, but I'm not going fast at all?
    Any suggestions?
    Thanks.
  2. Feb 15, 2010 at 1:18 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    if you run out of brake fluid they may be locking up really easily...
  3. Feb 15, 2010 at 2:29 AM
    dwntwnall4u
    Kevin
    san diego
    Just checked, brake fluid is fine.
  4. Feb 15, 2010 at 4:15 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Does it occur when you step on the brakes?
    When was the last time you changed or checked your brake pads? The pads have a 'wear indicator' on them that'll rub againest the rotor when the pads are bad. This metal on metal will cause screeching - telling you its time to replace your front brake pads.
    http://auto.howstuffworks.com/auto-parts/brakes/brake-types/disc-brake4.htm
    Other than that....
    We need more information..... You also might have something (stone) stuck in there. Try going in reverse and stepping on the brakes several times - this might dislodge whatever is in there.
  5. Feb 15, 2010 at 4:26 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    this
    :thumbsup:
    if its your tires and not your brakes...maybe its time for new tires
  6. Feb 15, 2010 at 4:43 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Maybe because you're in California?
    I know the same thing used to happen on the Rockford Files.
  7. Feb 15, 2010 at 4:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Check tire inflation and alignment....and the brakes.
    My tires were slightly misaligned after my lift....but it was even misalignment- So the truck drove straight, but squealed in turns.
  8. Feb 15, 2010 at 5:06 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    could be the type of asphalt you know how in a parking garage no matter what you do your tires will squeal.
  9. Feb 15, 2010 at 5:20 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    And Starsky and Hutch! You may be on to something here.
  10. Feb 15, 2010 at 5:26 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This was my thought also. :notsure:
  11. Feb 15, 2010 at 5:38 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Alignment. ;)
