To buy or not to buy wheel spacers and why
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dontstealmyride, Feb 10, 2016.
Would you buy wheel spacers?
  1. Yes
    206 vote(s)
    58.5%
  2. No
    61 vote(s)
    17.3%
  3. Hell no
    85 vote(s)
    24.1%
  1. Feb 18, 2016 at 11:00 AM
    #41
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    No. I like my scrub radius just fine.
  2. Feb 18, 2016 at 11:00 AM
    #42
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    That's why I asked! thank you
  3. Feb 18, 2016 at 11:04 AM
    #43
    smugly
    Doug
    He does have a good point! Baconpower. what say you?
  4. Feb 19, 2016 at 2:02 PM
    #44
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    Indeed Toyota-made TRD wheels come in various offset values: https://www.tacomaworld.com/threads/wheel-specs.30754/
    And I do not honestly understand why.
    I would have guess that no matter how wide the rim is (6", 7.5"), the offset would have been the same since it's measured from the center of the rim, but it's not the case: according to the link above, offset values change with rim width on Toyota-made rims. I do no know why. BTW I assume but can't double check that these values are accurate either.
    Anyone knows?
  5. Feb 22, 2016 at 11:52 PM
    #45
    TACOtrux
    TACOtrux Active Member
    Pheng
    Clovis
    2012 MGM DCLB 4x4
    Discount Tires (Purple logo/signs) does alignments, not Americas Tires (Red logo/signs). Don't know how long Discount tires has been doing it but they have the lifetime alignment for around $180 for as long as you own the vehicle, and if the vehicle is lowered or raised, then you pay another $80 to keep the lifetime deal. Sounds promising for 4x4 trucks, since alignments may be needed after off-roading. But take it in a few times, and the excuses start coming as to why they can't get the alignment done properly.
  6. Feb 22, 2016 at 11:59 PM
    #46
    TACOtrux
    Pheng
    Clovis
    2012 MGM DCLB 4x4
    My miscommunication... business in my area is "Discount Tire Center" (purple logo/signs). You are correct, Discount/America's Tire (red logo/signs)are located here too, and they only to tires, no alignment.
  7. Feb 23, 2016 at 12:00 AM
    #47
    TACOtrux
    Pheng
    Clovis
    2012 MGM DCLB 4x4
    My miscommunication... business in my area is "Discount Tire Center" which has purple logo/signs. You are correct, Discount/America's Tire are located here too, and they only to tires, no alignment.
  8. Feb 23, 2016 at 7:03 AM
    #48
    littlechilds
    littlechilds skyhawk
    Cowtown
    16 trd sport Upgrade package DCLB
    KO2 tires, TRD pro rims. BP skid plate, Extang 2.0 cover, dipped grill and badges
    Well, I'm stuck with my 265/70/17 K02 tires and TRD Pro rims(great set up), after reading hundreds of people claiming they don't rub).
    Lets just say, when turning, it does not take much of a bump to rub!
    So now I'm debating on the $89 spacers (probably get dealership to install???), or $1800 suspension lift. I really don't want to fork out more money into this truck. I'm also still dealing with a slight shimmy the dealership can't seem to get rid of re-balancing.
  9. Feb 23, 2016 at 10:00 AM
    #49
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    For those who run the 1.25" spidertrax, do you need to get alignment done when adding them?
  10. Feb 23, 2016 at 2:14 PM
    #50
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    no you don't
  11. Feb 23, 2016 at 2:46 PM
    #51
    WarrenG
    WarrenG Well-Known Member
    I reluctantly put 1 1/4" spidertrax on my gen1 tundra to clear tacoma rims for my winter tires. Use red loctite generously, and recheck after a few hundred km. My rears were a few ft/lb loose, front was fine.
    Having said all that, there has been no ill effects from the install and i frequently have over 1000# of sled, deck and gear for long distances. Just dont like worrying about the extra set of nuts that "could" come loose...
    SportsmanJake likes this.
  12. Feb 23, 2016 at 2:47 PM
    #52
    Aussiek2000
    2016 Offroad AC
    I just checked the torque on mine after 2000 miles. None of the nuts budged
  13. Feb 23, 2016 at 5:30 PM
    #53
    splitbolt
    NW Arkansas
    I don't have them, but I'd imagine you would want to run more toe in.
    http://www.4wd.com/jeep-parts-resource/jeep-lift-kits.aspx
    I recommend the rest of the videos by Engineering Explained in the above link, if you're into that stuff.
  14. Feb 25, 2016 at 6:26 AM
    #54
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    :rofl: so I bought spacers the other night..not sure that I will even need them, but I feel sick to my stomach about the idea of possibly having to install them
  15. Feb 25, 2016 at 1:08 PM
    #55
    littlechilds
    Cowtown
    Where's the best place to get a set of 4 1.25" spidertrax spacers? Im seeing $99US for a pair of 2. I assume most do all 4 tires?
  16. Feb 25, 2016 at 1:21 PM
    #56
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I put 1.5" on, no alignment was needed.
  17. Feb 25, 2016 at 1:23 PM
    #57
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    It's possibly because the 17" Sema TRD wheel was specifically designed for the 4Runner and the 16" TRD wheels was designed for the FJ and Tacoma. Different platforms with different stances, geometry ect. Just because they all have the same lug pattern doesn't necessarily mean all wheels should be designed equally.
  18. Feb 26, 2016 at 6:02 AM
    #58
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    No thanks..don't want the Billy Bob look huge tires sticking out beyond the fenders... I got the sport version for a reason....Heck I might slam the baitch and put some 22s on her...lmmfao
  19. Jan 22, 2019 at 8:32 AM
    #59
    bgreyc
    bgreyc Well-Known Member
    Brad
    Albuquerque, NM
    '19 Silver TRD Off Road DCLB
    Lighting: BD S2 Sport Flush Mount Rear Bumper Lights (Work) BD Squadron Pro Driving/Combo Fogs (Amber) BD S2 Pro Ditch Lights (White, Off Camber Hood Bracket) KC Hilites Cyclone Under Hood Lights KC Hilites Cyclone Pair - Shell Lights 30" Rough Country Black lower grill light bar Raxiom Bluetooth Light Switch Accessory Controller Suspension Teraflex 2" Falcon Load/Haul Suspension Tires BFG T/A KO2 C 265/70R-17 Wheels Fuel Wheels - Vector Gun Metal (17x8.5) MESO Mods Coin Tray Dome Light Map Lights Key Fob - Orange/Red Keys @OneMoreTaco Radio Knobs TRD Pro Grill - Runnin4Tacos ARB Single compressor (Underhood) GTFO Expedition Compressor Bracket Runnin 4 Tacos - White Grille Lights - 4 Caliraised Bed Stiffeners Redline hood struts Bedrug Bedliner KTJO4x4 Tail Gate Auto Lock Kit Dual camera setup - Anytime front/rear Camera Runnin4Tacos - TRD Off Road Emblems Victory Blitz Rock Sliders Victory Top Rack Ordered (delivered, need time) Victory 4x4 Center Console Molle Wish List Victory 4x4 Blitz Front Bumper Victory 4x4 Strike Rear Bumper
    I was told they were designed with a range of offset. so I think if you don't overdo it, I think you will be fine. I am installing a Falcon Suspension this weekend, did a lot of research with them to see about trimming the rear shock bucket. I didnt want to do trimming, so I looked into aftermarket wheels and also wheel spacers. I have decided to go with a spacer. I think whomever said that the bearing are designed for a certain offset is right, but I do think designers take into account a range for the design. I am going to use the spidertrax spacer, make sure they are torqued and go from there.
  20. Jan 22, 2019 at 9:34 AM
    #60
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    I’m looking at the falcons as well,, how much more space do ya need for no trimming ? Thanks
