To Lift Or Not To Lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by drp.deluxe, Jan 8, 2018.
  1. Jan 9, 2018 at 5:31 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Crater Lake?
    aidenbeck likes this.
  2. Jan 9, 2018 at 9:22 AM
    NV_Spencer
    NV_Spencer Well-Known Member
    2020 CREWMAX / 2017 OR DCSB
    Looks fantastic but do you get any rub or clearance issues?
    cooper s/t maxx?
  3. Jan 9, 2018 at 10:02 AM
    drp.deluxe
    drp.deluxe [OP] New Member
    Randy
    2017 Quicksand Tacoma TRD Off Road
    WOW you guys have "NO IDEA" how much I appreciate your input. You have defiantly helped me make a much better and more informed decision. I am going to go with like a 2.5 shocks and coil-overs (Probably Billsteins since I had them on my JEEP) and wheels and tires. Will post a picture when I get it done, Might be a little bit since I am out with shoulder surgery right now. Thank you all very much.
    kap1425 likes this.
  4. Jan 9, 2018 at 11:59 AM
    Tacoroach
    Tacoroach Well-Known Member
    Vancouver, BC
    2017 DCLB
    Are those 275/70/17s?
    Looks nice
  5. Jan 9, 2018 at 2:16 PM
    dannynoonan
    dannynoonan Well-Known Member
    Yes. Cooper ST Maxx. No rubbing at all. No rock crawling, but I did try to make them rub last time I was in the mountains. None so far.
  6. Jan 9, 2018 at 2:22 PM
    Dylan_ElDoradoCo
    Dylan_ElDoradoCo Well-Known Member
    Dylan
    Pollock Pines, Commiefornia.
    2nd Gen Super White DCLB
    I'm running 33"×12.5" wheels have the fox series 2.0 lift with adjustable coil overs, made a few adjustments and it works like a top.
  7. Jan 9, 2018 at 3:37 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Yes sir!
  8. Jan 9, 2018 at 3:37 PM
    Rustytaco71
    2018 4Runner
    Yes.
  9. Jan 9, 2018 at 3:38 PM
    thumpertx
    thumpertx Well-Known Member
    2003 silver TRD4X4, 2017 quicksand TRD 4X4
    Look at Firestone or Air Lift brand air bags for your truck. You can haul twice that many sandbags and have a perfectly level truck. They are not very expensive and easy to self install.
  10. Jan 9, 2018 at 3:47 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Where I wheel, moderate offroading is fairly tough. I have wheeled moderate trails here in NH with a stock Taco, and while it can be done, a 3 inch lift helps to get the front diff and frame off the rocks and allows you to take much more difficult trails. It gives you better approach, departure and break-over angles, and it increases overall ground clearance. Forget people who say a lift doesn't give you ground clearance...that is false. It is true that a lift will not increase your lowest point of clearance, namely your rear differential. The only way to raise that is with larger tires. Every other point of clearance, however, is higher after a lift. It makes wheeling easier, you can clear rocks in the front and on the sides because your front diff and frame are higher. Then all you have to do is snake your rear diff between some rocks, or get a rear tire on a rock to clear the diff. For me, if I wanted to do moderate wheeling, a 3 inch lift and 32s or 33s would be my starting point. To be honest, I would rather have a 3 inch lift and 32s than a leveling kit and 33s for wheeling.
    Jukeboxx13 likes this.
  11. Jan 9, 2018 at 4:26 PM
    NV_Spencer
    Jibbs, aidenbeck and oscolivar1 like this.
  12. Jan 9, 2018 at 5:03 PM
    aidenbeck
    aidenbeck Well-Known Member
    Aiden
    Oregon
    2012 Toyota Tacoma
    Main Line Overland Four Wheel Camper flatbed build @searchingforseagulls on Instagram
    This is pretty much what I am thinking for my truck but am open to all feedback.
    275/70/17 BFG All Terrains
    700# king coilovers and 600lb springs (future skid, bumper, winch)
    OME Dakar leafs with add a leaf
    Timbren bump stops
    King adjustable rear shocks
    Firestone Ride-Rite airbags (future camper)
  13. Jan 9, 2018 at 5:31 PM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    unclejunk likes this.
  14. Jan 10, 2018 at 8:23 AM
    NV_Spencer
    how much extra weight are we talking...? You think I'd be OK with bolt-on sliders & a RTT?
  15. Jan 10, 2018 at 10:01 AM
    #35
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    So I'm planning on an aluminum bumper so up front I'll have about 150 between that + winch. I'll also be running sliders, bed rack, and eventually RTT. I have a storage box full of recovery stuff that lives in the bed which is probably about 90 pounds, and a cooler in the summer.
    If you run an empty bed then just the RTT might be fine
    With those things I've had no issues but I would rather be safe than sorry, because I might upgrade my skids too.
  16. Jan 10, 2018 at 10:39 AM
    #36
    NV_Spencer
    I generally always have bins of camping gear/5 gallons of water in the bed when I go out. Maybe look for something smaller than 85 ratio to be safe?
  17. Jan 10, 2018 at 10:45 AM
    #37
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    This. Your wheel choices have to do a lot with whether or not you're going to rub on 285s. There's a video of some guy running 285s on stuck suspension without rubbing and he just used a heat gun on his fenderwell to remold it. Now if you run skinny 255/85/16s, you're not going to rub for sure. But if you go 285/75/16 or 70/16 a lot depends on your wheel specs.
  18. Jan 10, 2018 at 10:48 AM
    #38
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Not entirely true- you need to be on stock wheels for this. There are plenty of aftermarket 16s that will push you back far enough to rub on the fender lining even with 255s.
    rlx02[QUOTED] likes this.
  19. Jan 10, 2018 at 10:49 AM
    #39
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Sorry, shoulda mentioned stock. I ran 255's (see avatar) on OEM steelies and they didn't rub whatsoever. I had to adjust my coils and do some minor trimming when I went to 285/70/17s though.
  20. Jan 10, 2018 at 12:50 PM
    #40
    NV_Spencer
    Where'd you get your steelies? Such a classic look...
