To many options..... Need help!!!
Discussion in 'Wheels & Tires' started by teambcw, May 16, 2010.
  1. May 16, 2010 at 9:13 PM
    teambcw
    teambcw [OP] Well-Known Member
    So Cal
    I know a ton of people have asked what tire to get but I didnt find exactly what I wanted to know. I am looking for A/T tires that will do good on road being that I am 90% pavement 10% offroad. I dont want to spend a good amount on tires that will wear out super fast on the road. I also wanted to know what size to run? I have the rear tsb and I am adding 5100 set at 1.25 in the front next week. I dont want to rub, going on 17 rims. Thank you for the help as always! Jason
  2. May 16, 2010 at 9:15 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I had good experiences with the TOYO Open Country A/T and the COOPER Discoverer ATR.
  3. May 16, 2010 at 9:18 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Check out the Hankook A/Ts...They have a pretty aggressive tread pattern and there rated for 50k. I have em and I like em alot...I just wish they were 285s :eek:
  4. May 17, 2010 at 6:09 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    +1 for the hankooks. Love the tread pattern, and they are quiet.
  5. May 17, 2010 at 6:10 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    I've been happy with my BFG A/T. Good ride on and off road.
  6. May 17, 2010 at 7:59 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    I've been happy with my Toyo's, I'm on my 2nd set and they've lasted 3 years now. Having said that, my next set of tires is going to be the Hankooks posted above, they look to have a bit better winter traction.
  7. May 17, 2010 at 8:04 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I have been really happy with my PIRELLI Scorpion ATR. I have about 30k on them and still have more than half tread.
  8. May 17, 2010 at 8:12 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    +1 for the Hankooks. 50k mi and can get all 4 for under $600 mounted and balanced. Not a bad deal. They've been great for me so far on pavement, trails, mud, and rain after 3,000 miles.
  9. May 17, 2010 at 9:05 AM
    under1630
    under1630 Retired UPS driver
    Jon
    Las Vegas, NV
    '08 PreRunner SR5 TRD Off Road
    Full cab Dynamat, Bilstein 5100's, aFe cat back exhaust, aFe stage 2 CAI, aFe throttle body spacer, 16x8 MotoMetal 951's, Hankook DynaPro MT 295/75 16
    What model Tacoma do you have?
    Is your Taco level?
    Do you want it to be level?
    Are you going to put a lift in the rear?
    What kind of appearance are you seeking?
    What size tires do you want to run?
    Why do you want 17's? 17's will tend to give you a stiffer ride than the same height tire in 16's because there is less sidewall height in the 17's. (More sidewall height = more cushioning).
    Are you willing to run spacers?
    Why don't you have the 5100's set at 2.50? When I did this on my 08 Prerunner Off Road, it leveled the Taco out perfectly.
    Now before you go out and buy some tires because someone recommends them, you have to do your own research. An important thing to keep in mind is that your wheels and tires are rotating weight and will have a direct impact on engine performance. On my Taco, the stock weight of each tire/wheel combination is 60lbs. My original tires weigh in at 37lbs. If you want to go to 285/75R 16's which is probably the best size for our Tacos in terms of height and width and bad ass looks, then you will be looking at anywhere from 55 to 63 lbs per tire only. In other words you will be adding about 20 lbs of rotating weight on each corner. Also keep in mind that this weight is as far from the parts that they put stress on which is another thing to keep in mind.
    Another thing that people forget is that when choosing a tire size, you will never see the advertised height when it's installed on your vehicle. That is because the weight of the vehicle will compress the tire, thus reducing it's height by about 1". If you choose not to lift the rear of the truck or move the clips on the 5100's to 2.5", then I think you should stick with a tire that is about 32" in height. For each inch in increase over the stock tire size, your tire will rise in the wheels well by 1/2". The other 1/2" will be in vehicle lift.
    Next come the wheels. I hope you don't want to go to 17's cuz you want "bling" wheels. That would be tantamount to putting lipstick on a linebacker. It just wouldn't look right, and many would consider it gay. You want to find wheels with a maximum of 4.5" of backspacing, and 4" would be much better.
    My opinion would be to look at Mickey Thompson for both the wheels and tires. Made here in the USA, and giving back to a pioneer in the off roading community.
    http://www.truckaddons.com/Catalog/subpages/mickeythompson_main.htm
    *Here's a link to wheels backspacing and offset explained:
    https://www.rsracing.com/tech-wheel.html
  10. May 17, 2010 at 10:01 AM
    teambcw
    So Cal
  11. May 17, 2010 at 11:29 AM
    under1630
    Jon
    Las Vegas, NV
    OK,
    Here you go. The Mickey Thompson Baja Radial MTZ
    http://www.truckaddons.com/Catalog/subpages/mickeythompson_bajaradial_mtz.htm
    Model Tire Size Weight Rim Range Rim Used Width Tread Width Height
    5271 LT265/70R17 53 7-9 8 10.8 8.3 31.9
  12. May 17, 2010 at 11:34 AM
    David K
    Mud Tires are very noisy on the highway and expensive. I had Cooper Discoverer STTs on my '05... and while they look awesome on the truck, the road noise and terrible sand driving they gave meant never again, for me.
    Anyway, the guy is asking for all terrain/ highway tires... I gave him a couple I had (after the STTs) that worked very well, and were not pricey.
  13. May 17, 2010 at 11:53 AM
    under1630
    Jon
    Las Vegas, NV
    1. These are not mud tires. The MTZ stands for maximum traction. Do your research!
    2. What is a higway? Can you post a picture of one?
    3. He didn't say anything about noise. Maybe, just maybe he's not a pussy. 4. Per Mickey Thompson website:
    • Advanced Radial Construction for High Mileage & Smooth Ride
    • Self Cleaning High-Void Tread Lugs for Traction in Nasty Shit
    • Deep Shoulder Lugs Provide Aggressive Traction and Bold Looks
    • Enhanced Sidebiters® for Added Traction & Protection
  14. May 17, 2010 at 11:55 AM
    Evans381
    Evans381 Well-Known Member
    Ty
    Rome, Georgia
    06 PreRunner
    Toytec ultimate coilovers. 5% Window tint. 40% windshield. Kenwood DDX372BT Monitor. JL Audio 12w0v3 subwoofer set in ported Q-Bomb box. 20" Gear Alloy Recoil wheels wrapped in Cooper Zeon LTZ tires
    Mickey Thompson ATZ
  15. May 17, 2010 at 11:56 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    lol quick to call the man out.
  16. May 17, 2010 at 1:43 PM
    KPT
    09 Prerunner
    Wow way to be a dick about it.
    And how does not wanting extremely loud tires make you a pussy. I bet you have straight pipes too :rolleyes:.
  17. May 17, 2010 at 1:55 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    ...I don't care what the MT marketing team calls them. Those are mud tires.
    Cooper's STT stands for Super Traction Tread:
    And they be some mud tires too. Anything with lugs that big and that aggressive is an MT.
  18. May 17, 2010 at 1:59 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    the mtz's are a mud terrain, thats now what the guy is looking for
  19. May 17, 2010 at 2:40 PM
    petyanca
    petyanca Well-Known Member
    bay area
    09 AC 4cyl 4x4 5spd
    This is from the link you posted:
    Baja Radial MTZ:
    Extreme off-roaders will appreciate the great ride and handling that this mud tire has on the highway. The MTZ Radial has Mickey Thompson's Power Ply™ sidewalls with a special angled third ply to give you high performance handling, better puncture resistance, and improved towing capability.
  20. May 17, 2010 at 2:41 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    ya im pretty sure hes eating his words lol, anyways what tires do you think your going to go with teambcw?
