To regear or not to...oh who are we kidding, we are regearing!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Overkill07, Jan 16, 2017.
  1. Jan 20, 2017 at 10:56 PM
    #81
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    You'll have to look it up on how to use it cause I have a first gen and I'm not sure how to get it into ATRAC mode, but your truck should have ATRAC. Essentially it is a very sensitive traction control that acts as a front locker. From what I've heard, it's really good and adding a locker on top of that isn't really necessary.
  2. Jan 20, 2017 at 10:57 PM
    #82
    smmarine
    Melbourne FL
    Obviously a mechanical locker is going to be better then traction control, but unless you're planning on rock crawling I don't think you'll need it.
  3. Jan 20, 2017 at 11:05 PM
    #83
    smmarine
    Melbourne FL
  4. Jan 20, 2017 at 11:07 PM
    #84
    smmarine
    Melbourne FL
    Also, since you already have an elocker in the rear, unless you're dead set on a front ARB and having air lines and a compressor etc, you may consider a Harrop Elocker for the front. My first gen has Harrop Elockers front and rear.
  5. Jan 21, 2017 at 1:57 PM
    #85
    Overkill07
    Overkill07 [OP] Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    huh....
    Well we do a lot of rock crawling on the trails we take. I have a tendency not to take the bypass, hence why my $hit is broke :anonymous:
  6. Jan 21, 2017 at 5:20 PM
    #86
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I didn't see a bypass
  7. Jan 23, 2017 at 5:29 AM
    #87
    Overkill07
    Warren
    Texas
    14 TRD O/R DC MGM
    LOL, you never see a bypass!
  8. Jan 23, 2017 at 5:48 AM
    #88
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I'm normally following you
  9. Jan 23, 2017 at 1:23 PM
    #89
    Overkill07
    Warren
    Texas
    14 TRD O/R DC MGM
    Well putting my truck on hold while I fix the wife's Heep and my daughters car. Got to take care of my girls first.
    BulletToothTony likes this.
  10. Jan 23, 2017 at 2:55 PM
    #90
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Stabilizer
    Track bar
    Ball joints
    That's the cheapest order to try it out.
  11. Jan 24, 2017 at 6:33 AM
    #91
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    So without the core charge, you got it for $900? That sounds like the deal of the century if that's true. I can't even find the Harrop elocker on the ECGS site!
  12. Jan 24, 2017 at 6:54 AM
    #92
    smmarine
    Melbourne FL
    That's cause ECGS doesn't sell Harrops. I bought it and had it shipped to ECGS. And their install was actually $1000. Not sure how I messed that up. Machining to fit E-locker, new ring and pinion gears, seals, bearings, etc. After core charge was $700.
    If you want more info on the elocker, PM me. I have a thread for the lockers, and there is a 2nd gen member who has one too.
  13. Jan 24, 2017 at 8:58 AM
    #93
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I think I'd do my air lockers again if I had to. Id rather blow my truck to make the lockers work then mess with electronics
  14. Jan 24, 2017 at 10:09 AM
    #94
    smmarine
    Melbourne FL
    You talking about the Harrops? Only 2 wires run it
  15. Jan 24, 2017 at 11:41 AM
    #95
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    The magnet doesn't worry me to much but it's the internals that do. I've got e lockers on my 80 series and they dont engage quickly and are a little finicky. Ive seen the Harrop before I purchased the ARB and I get a lot of mixed reviews the main one being they are not as strong. Specifically the slide gear. ARB is multi tooth design and don't know the official terminology but Harrop is not and some still use dowel pins. Warren you've messed with the e locker and ridden with me to see how quickly the ARB activate and deactivate. I'm sure the Harrop vs ARB is 6 one way half a dozen the other. Both have pros and cons. Whatever you do get the front locker.
  16. Jan 26, 2017 at 8:22 PM
    #96
    Overkill07
    Warren
    Texas
    14 TRD O/R DC MGM
    I will be locking the front as I do not want to have to worry about not being able to crawl over obstacles. The Skinny pedal is not always your friend.
  17. Jan 28, 2017 at 6:39 AM
    #97
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Not always your friend? When did y'all break up?
  18. Jan 31, 2017 at 6:09 PM
    #98
    robrides
    robrides Active Member
    03 DC then 05 TRD OR then 2015 TRD Sport 4x4
    ICON Stage 2, 31x10.5, ARE Topper, Fuel Wheels, Anytime Backup Camera, Electric Brake Controller, Ultra-Gauge, K&N filter
    I went ECGS 3rds with ARB lockers front and rear on my 2015 DCLB Sport. $3200 with the CMKA12 air compressor after getting my cores back. Did the work myself back in summer 2015. Now, I haven't actually wheeled much, or any unless you count getting stuck down the hill in my backyard, so there is that. Without the lockers my truck might still be sitting down there :notsure:
  19. Jan 31, 2017 at 7:54 PM
    #99
    Overkill07
    Warren
    Texas
    14 TRD O/R DC MGM
    :anonymous:
    That was my inital thought process but since I have a TRD OR, I also have an 8" rear end. ARB does not offer a locker for the 8". I would have to swap out to an 8.4 and that is not something I think I am will to do right now.
    Unless I can find someone with an 8.4 that wants to trade to an 8 w/e-locker +cash......:rolleyes:
  20. Feb 2, 2017 at 3:46 PM
    #100
    robrides
    Well, actually I've been looking to move to a full size truck and have visited a few stealerships. Of course all the mods are freebies to them so I'm contemplating returning the rig to stock and trading in or selling out right. If I was a more active member on tacomaworld my rig would already be posted for sale. My guess is from your pictures, you're not local to me. I'm in the St Louis area on the Illinois side.
