Toneau cover/Bed extender conflict
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black Sheep, Nov 6, 2010.
  1. Nov 6, 2010 at 4:43 PM
    Black Sheep
    Black Sheep [OP] Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    I have a little problem. I just installed my new toneau cover. The problem is that with the cover clamps at the back of the bed, they can not be fastened down with the bed extender in there. I have to take it out to clamp down the cover. I wanted to use the bed extender in the bed to keep things from sliding around the bed. It would double as a divider to keep stuff jsut inside the tailgate.
    Any one encounter this issue? If so, how did you deal with or make it work?
  2. Nov 6, 2010 at 4:48 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    What kind of tonneau cover do you have. With the Access covers due to the way they are mounted, you have to trim the extender about 1/2" on each side and then it works just fine
  3. Nov 6, 2010 at 4:56 PM
    Black Sheep
    Jeff
    Pittsburgh, PA
    I just put on the Tonno Pro. The problem that I am having is with the rear clamps, the bed extender interferes with them being latched when extender is folded in the bed.
  4. Nov 6, 2010 at 5:01 PM
    ImpulseRed008
    Susan
    SC
    I'm sure someone else on here has one and might be able to help... It's kinda slow so far this weekend... might take a day or two to find someone able to help.
  5. Jan 4, 2011 at 7:20 AM
    razortaco
    razortaco Well-Known Member
    Houston, Texas
    2010 Black PreRunner TRD Off Road
    Bed Pocket Lights, Carriage Works Billet Grille, Aries Bull Bar with Warn Off-Road lights, Valor Exhaust Tip, OEM Tube Steps, OBX Sport Pedals, Stubby Antennae
    OP - did you ever find a solution for this issue? I just ordered the Tonno Pro and was considering a bed extender as well but am curious if you were ever able to get it to work. Thanks!
  6. Sep 20, 2011 at 5:15 PM
    shoebag22
    shoebag22 Well-Known Member
  7. Sep 21, 2011 at 4:29 AM
    Black Sheep
    Jeff
    Pittsburgh, PA
    No, I have net been able to figure it out. I have thought about cutting the lock down latches on the tonneau cover, but not sure if I want to do that yet. I just fold the cover back for now when I need to install and use the bed extender.
  8. Sep 21, 2011 at 4:33 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Did you get your cover from the dealer or manufacture? Either way you should have been told they can't work together. I almost made the same mistake. If you don't have one, get a bed mat. I have no idea what type of rubber they used to make it, but whatever you put onto it close to the tailgate well be there when you get home. They are the cats ass.
    Frank
  9. Sep 21, 2011 at 5:01 AM
    silver11
    silver11 Active Member
    mass
    2011 off road
    Hid head lamps,fog lamps, color matched door handels, mirrors,and grille,bed cover,weather techs,
    I had the same issue with my cover I ended up triming down the handels that lock it down and now it works great with my extender.
  10. Sep 21, 2011 at 5:04 AM
    Highland Logan
    Frank
    Nova Scotia, Canada
    What type of cover?
    Frank
  11. Sep 21, 2011 at 6:46 AM
    Black Sheep
    Jeff
    Pittsburgh, PA
    That is what I wanted to do with them also to make them work together.
  12. Sep 21, 2011 at 6:49 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
