Toneau Cover - Which one is everyone using?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black Sheep, Oct 27, 2010.
  1. Oct 27, 2010 at 2:39 AM
    Black Sheep
    Black Sheep [OP] Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    I am now looking for a Toneau cover. I found one on Ebay, the Tonno Pro, for $269. My local truck accessory place has one for $350. Anyone have any info or advice on one? I want to get one pretty quick.
  2. Oct 27, 2010 at 3:29 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Been pleased with my BakFlip cover.
  3. Oct 27, 2010 at 3:56 AM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    I just recently installed the TRUXEDO low pro qt and I like it so far. Very easy to use.
  4. Oct 27, 2010 at 4:01 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    I have the undercover which is a hard cover that hinges open and has two gas springs for help. (http://www.undercoverinfo.com/) They do make a single lock style but that's not the one I have.
    PROS:
    +VERY easy to maintain and keep looking great
    +Very sturdy and seals out water/snow as well as thieves
    +Easy to remove and store (1 person can do it)
    +Has a LED light (not the brightest but just enough in the dark)
    CONS:
    -two locks/levers but you can buy them with one lock
    -sometimes is a pain when you have something in the bed that is just a bit higher than the cover itself.
    -pretty pricey
  5. Oct 27, 2010 at 4:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm running the Lund Genesis soft tonneau. It was cheap and I absolutely did not want a snap cover. I like it because it sits on top of the bed rails so there's more clearance for things you put in the bed vs tonneaus that sit flush with the rails (I have a big cooler I go camping with that's the same height as the bed rails so this was important for me). Very easy to roll up and out of the way or remove if you wish. It came with a big steel box piece to fill the gap at the front of the bed which I never installed. It blocked the entire front bed rail so I just stuck a piece of foam in the gap and so far it supports itself just fine (2 years and counting).
  6. Oct 27, 2010 at 8:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Advantage Torza top (trifold)
  7. Oct 27, 2010 at 8:16 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
  8. Oct 27, 2010 at 8:17 AM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    i have an access softcover,like it alot
  9. Oct 27, 2010 at 8:27 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Fold A Cover G4 Elite. It's a hard foldable cover and I'm really happy with it.
  10. Oct 27, 2010 at 8:27 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    EFX Trifold (same as the Advantage tri-fold, just rebranded) Love it.
  11. Oct 27, 2010 at 8:32 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    im lovin my Undercover so far
  12. Oct 27, 2010 at 8:32 AM
    Gunga
    Gunga Well-Known Member
    Glendale, AZ
    2008 TRD OffRoad DC 4x4
    Fold A Cover G4 Elite. Very happy with it.
  13. Oct 27, 2010 at 10:10 AM
    claw
    claw Well-Known Member
    Cam
    Bozeman MT
    2010 Access Cab, 4 Banger
    Tonneau cover, bed lights, fog lights, VHF radio
    x2 Truxedo LoPro QT. Simple install, seems watertight so far, very small footprint (everything is still accessible when the cover is rolled up)
  14. Oct 27, 2010 at 10:15 AM
    whattheheck
    whattheheck Member
    2010 Tacoma SR5 Sport
    I have the Roll-n-lock cover and have had no issues with it. :D
  15. Oct 27, 2010 at 10:17 AM
    superminsoo
    superminsoo Well-Known Member
    Snuglid SL from Snugtop. Best looking one out there imo. Keeps things 100% dry and locks the tailgate. Couple downsides are that you have to push it down to open it, the inside bolts rusted, and it cost 900 but i'm satisfied.
  16. Oct 27, 2010 at 10:19 AM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    it does look nice, but my dad has the snuglid and its pretty heavy compared to the Undercover
  17. Oct 27, 2010 at 10:23 AM
    superminsoo
    I've never used an undercover but they had some good reviews. There were only so many covers that came factory color matched.
  18. Oct 27, 2010 at 10:44 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have the access literider. $280 shipped from truckalterations.com (vendor on here)
    I love it! It rolls up and out of the way in seconds. The velcro makes dealing with weather changes easy (everyone knows the snaps can be a pain in the cold). Only leaks a trickle of water at the front in really heavy rain. Also with the Access (agricover) tonneau's the cross bars roll up with the cover so you don't have to store them. Also I still retain use of my factory tie down cleats.
  19. Oct 27, 2010 at 10:44 AM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Snuglid SL FTW
  20. Oct 27, 2010 at 11:00 AM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    I'm thinking about getting one of those roll top covers, like a Retrax or something.
