Tonneu Cover! for 07?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Critter, Jun 6, 2007.
  1. Jun 6, 2007 at 10:23 AM
    Critter
    Critter [OP] Well-Known Member
    :) I just bought a 07 4x4 Tacoma Crew Cab 5' bed with roof rack. It has the bed liner with with the adjustable sliding load ties near top of bed. Looks like installing a Tonneu cover with this in place will be a problem! Does anybody know if anybody makea a cover for this truck equipted this way. I hate to order a cover and have to ship it back cause it won't work! Any info,advise is appreciated!
    PS Came over to Tacoma from 06 4x4 Frontier KC,I like this TOY alot!
  2. Jun 6, 2007 at 11:34 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Depends on what kind of cover you are looking for.
    I am partial to hinged soft covers, so that is what I can answer from. On my 04 I had I a Sportmaster hinged cover. That will NOT work on the gen II beds. A Sportmaster regular soft cover will mount fine, but for some reason they have had 3 years now to figure out the mounting for the gas shocks and can't do it.
    So on my 07 I have an Extang Full Tilt soft cover. This mounts up to the gen II beds very nicely, permits use of the factory cleats still, and is in many respects nicer than the sportmaster.
    Expect to pay in the $400.00 range for either.
    Just my $0.02
  3. Jun 6, 2007 at 9:44 PM
    sgoveas
    sgoveas Member
    Anyone with an Extang Trifecta soft cover?? I was thinking of getting one when my Taco arrives. What are your opinions on it?
    are there any fitment issues with the short bed?
  4. Jun 6, 2007 at 11:02 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    Agricover Access LE. http://www.agricover.com/
    Check the videos.
    The Access Lorado is nice too, but it's so low profile that only the mini-cleats can be used. With the Access LE you can use the stock cleats.
  5. Jun 7, 2007 at 3:19 AM
    Critter
    Thats the problem the sliding cleat system has rail 2" from top of bed, looks like it would interfer with most cover installations! Also the bedliner blocks access from using mounting clamps you would have to cut holes to use them! Not an option with me! If the lip of frame is 2' or more I might be able to use self tapping screw to hold it in place! I'm in hurry at present so I'll just look and listen to feedback and do some Web Surfing! Thanks for Help!
  6. Jun 7, 2007 at 2:57 PM
    pb2themax
    TRD Sport 4x4
    That's what I'm saying. Get the Access LE. Your cleats will work perfectly if you get the LE. It doesn't use clamps that get in the way. It's mounting system fits behind the rail.
    If you get the Lorado then the cleats won't work. I like the low profile of the Lorado though.
    But anyway, take a look at the Access LE. Read through this thread. It's mostly about the Lorado, but there is also some pics of the LE. http://www.toyotanation.com/forum/t118926.html
  7. Jun 7, 2007 at 6:37 PM
    A2Mich
    A2Mich Well-Known Member
    Jackson, Michigan
    07 Silver Streak Double Cab PreRunner SR5 V6 TRD Sport
    Tube steps, Toyota Bug Shield, Lund Tonneau
    The Lund Genesis covers work well and come with clamps that slide right into the rails, and still allow full use of the tie down cleats....bought mine for like $200 from AutoAnything.com
    Hope this helps...
  8. Jun 7, 2007 at 7:29 PM
    kngharley
    kngharley Well-Known Member
    Corona, Ca
    I have a Snug Top on my 07 Taco Sport they use the rails for mounting It works very well!
  9. Jun 8, 2007 at 12:44 PM
    midV6size
    midV6size Active Member
    I currently have a A.R.E. LS II lid on my truck, but after getting the lid, I don't care for it now that I've had one on for a while. Your restricted on what you can haul in the back of your truck, height wise!!
    Next truck, I'll be getting one of these, a Torza top!! Here's a link.
    http://www.truckaddons.com/Catalog/subpages/torza_tops.htm
  10. Jun 11, 2007 at 3:20 AM
    Critter
    I've seen a few of them and I like the idea,it gives you bed access without much hassle and goes back down just as easy. I may explore and research it to see if one would work on my 07!
  11. Jun 11, 2007 at 6:00 AM
    kaisersteiner
    kaisersteiner Active Member
    The "Lund Genesis Seal & Peel Tonneau Cover" says it requires removal of the rails but A2mich says it does not. Can we confirm that? I would like to order one but do not want to remove the rails as I do use them quite often.
  12. Jun 11, 2007 at 10:15 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
  13. Jun 11, 2007 at 11:29 AM
    Critter
    But Dam the price about 600 bucks give or take and thats for my 07 5 ft bed.
    Well this maybe my last p/u and if I look at it that way the extra $$$ maybe worth it over the next whatever! It is a very nice cover!:)
  14. Jun 11, 2007 at 11:41 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Don't get me wrong - I am DEFINITELY looking out for the money tree.
    My father-in-law had one of these on his 02' Silverado. It was strong enough to strap a bunch of stuff on top of it, and secure enough that he left his tank inspection equipment in there...
    I figure, if I am going to get a tonneau cover, I am going to get one that is everything I need: strong, durable, secure, quiet, good looking, and most importantly - easily removable (I want to use my truck bed whenever without taking off a one piece hard top)...
  15. Jun 11, 2007 at 7:03 PM
    Sneakers
    Sneakers Member
    I purchased an Access Limited Edition cover from www.truckalterations.com The price was less than $400.00 shipped. Easy install, able to use the stock tiedown cleats. Probably best of all lifetime warranty and no snaps. This cover uses hook and loop fasteners to hold the cover down.:)
  16. Jun 12, 2007 at 6:07 AM
    pb2themax
    TRD Sport 4x4
    ^ That's where I bought mine, and lots of other guys on Toyota Nation. Everybody loves the Access covers.
  17. Jun 13, 2007 at 7:01 AM
    confuzzed2
    confuzzed2 Member
    Colorado Springs, CO
    07 PreRunner
    I've got to jump on the Access band wagon as well! I love my LE! Thanks to PB and others I was easily persuaded. My 07 sport DC thanks them as well. :)
  18. Jun 13, 2007 at 9:00 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Stay away from the Bakflip. It's junk. I have one and regret getting it. I've spent more time gluing the pos back together....spend your money on something better. Go with a fold a cover if you want a folding cover.
    http://www.toyotanation.com/forum/t135474.html
  19. Jun 13, 2007 at 10:27 AM
    Critter
    Thanks Steve I'll heed your advice>:)
  20. Jun 13, 2007 at 2:40 PM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    i have the roll top cover and it was an install for me it is also an extang brand. i like the roll top because i can fit alot on my truck bed unlike the trifecta i know some people bought you can't fit alot of items on your truck bed hope this helps oh and no drilling required. :)
