TONY Spring Meet n Greet at BHM 4/17
Discussion in 'North East' started by drmk24, Mar 2, 2021.
  1. Apr 13, 2021 at 6:14 AM
    #221
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
  2. Apr 13, 2021 at 6:39 AM
    #222
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  3. Apr 13, 2021 at 6:44 AM
    #223
    Checkers10160
    Chess
    Thanks man, but unfortunately it's way more of a clunk than just a knock. I can feel it in my feet, like something bigger shifts. It only happens going forward, when I hit the brakes, the nose dips, and then the clunk happens as the truck rebounds. And only going forwards, not reverse
  4. Apr 13, 2021 at 7:02 AM
    #224
    racerrmh
    racerrmh Well-Known Member
    I won't be picking up my truck for another month or so or I would definitely be in for this meet up. First Tacoma and only my 2nd pickup ('87 s10 being my first ever vehicle). This looks like a must visit and well worth the 2 hour trip north. Maybe this summer and do some camping with the kiddo.
  5. Apr 13, 2021 at 7:10 AM
    #225
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    start looking at ballpoints and bushing for play. did you pinpint t to the font?
  6. Apr 13, 2021 at 7:12 AM
    #226
    jmferg
    jmferg Well-Known Member
    I’d throw everyone for a loop for unbolt the rear driveshaft from the t-case. Look what a FWD Tacoma can do
  7. Apr 13, 2021 at 7:13 AM
    #227
    Checkers10160
    Chess
    Yeah I'm pretty positive it's the front. I feel like the UCA have a tiny bit of play, I'll try to take a video later to show how much. Thank you!
  8. Apr 13, 2021 at 7:13 AM
    #228
    jmferg
  9. Apr 13, 2021 at 7:14 AM
    #229
    Checkers10160
    Chess
    I actually just replaced my passenger caliper, and both rotors, the noise happened before and after. However I will torque them down to double check, thank you! I'm hoping to put together a list of stuff just like this for later
    jmferg[QUOTED] likes this.
  10. Apr 13, 2021 at 7:15 AM
    #230
    12taco12
    rochester NY
    2012 TX Pro
    yeah if you can. worse comes to worse you'll have tons of guys to help fix it haha.
    gabbo2112 likes this.
  11. Apr 13, 2021 at 7:19 AM
    #231
    Checkers10160
    Chess
    I just really don't want to break down 180 miles from home lol. But it would be somewhat fun to do my first real trail repair with friends!
  12. Apr 13, 2021 at 7:19 AM
    #232
    jmferg
    I read through your post and the note of “happens in Neutral and drive” is important.
    Generally if you feel the issues in the floor or seat, it is drivetrain or rear end related.
    If you feel it in the steering wheel it is front end.
    Check your caliper mounting brackets bolts as well as your caliper mounting bolts. Check you control arms bushings, body mounts/bushings check that your trans mount is good as well
  13. Apr 13, 2021 at 7:22 AM
    #233
    Checkers10160
    Chess
    I could swear it comes from the front but I ONLY feel it in my feet. But that could just be something right below them, right? I'll have a coworker recreate it and I'll listen, or vice versa. Currently making a list of things to check the torque on, so far I'm at
    Alignment cams
    Caliper bolts
    Lower ball joint
    TOp hats
    LCAs
    UCAs
    Thank you so much everyone, I'm so sorry to derail this thread!
  14. Apr 13, 2021 at 7:29 AM
    #234
    12taco12
    rochester NY
    2012 TX Pro
    worth to check ujoints as well, grease em
  15. Apr 13, 2021 at 7:33 AM
    #235
    Checkers10160
    Chess
    The zerks on my driveshaft? I greased 3/5 of them recently, I couldn't find the other 2 lol
  16. Apr 13, 2021 at 7:57 AM
    #236
    12taco12
    rochester NY
    2012 TX Pro
    yes, check for play as well. doubt it is he culprit but nevertheless
  17. Apr 13, 2021 at 8:01 AM
    #237
    Checkers10160
    Chess
    Dumb question, can I literally just lay under the truck and wiggle it?
  18. Apr 13, 2021 at 8:16 AM
    #238
    12taco12
    rochester NY
    2012 TX Pro
    check the rubber caps for wear or gaps and then just grab and shake, small pry bar is great o use as well
  19. Apr 13, 2021 at 8:42 AM
    #239
    Checkers10160
    Chess
    Goddamn it guys. Cam bolts were not at 100 ft lbs but of course it moved a little and now the alignment is probably bad. And I just did the 'lifetime alignment' like 2 weeks and I think it's only every 6 months
  20. Apr 13, 2021 at 8:45 AM
    #240
    12taco12
    rochester NY
    2012 TX Pro
    there it is. but if they tightened them incorrectly they should realign and tighten correctly for free
    GarlicFarts and Checkers10160 like this.
