TONY Spring Meet n Greet at BHM 4/17
Discussion in 'North East' started by drmk24, Mar 2, 2021.
  1. Apr 5, 2021 at 12:47 PM
    #101
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    What is everyone using for comms?
  2. Apr 5, 2021 at 12:53 PM
    #102
    atpage
    atpage Well-Known Member
    Western NY
    You shouldn't *need* sliders on the easy side of the park. Unfortunately I haven't been on the rockier side. I assume they'd be more relevant over there. I was happy to have them for some tight turns between trees. But I could have made it without them.
  3. Apr 5, 2021 at 12:55 PM
    #103
    drmk24
    drmk24 [OP] Well-Known Member
    Dan
    2012 Black DCLB TRD Sport
    Good question. Didn't think of that. I don't have anything, but wouldn't mind grabbing a handheld if necessary....is it necessary?
  4. Apr 5, 2021 at 1:00 PM
    #104
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    Gmrs is the most common
    Just make sure it’s at least gmrs not frs in the long run it will be useless. CB use to rule the off-road game but the forecast has moved. Gmrs you can still get away without a license like you need with ham and the range of gmrs is plenty for most events and needs of people off-roading,hiking in groups, or camping
  5. Apr 5, 2021 at 1:01 PM
    #105
    atpage
    Western NY
    I'd suggest GMRS or FRS if you pick something up. Those will work with pretty much anyone else's FRS, GMRS, or ham radio. I'd avoid CB, since everyone else would need a CB for that to work.
    If you don't have one or can't borrow a spare from someone day-of, you'll have to honk your horn if you need something. And get out of the car to see what everyone else is planning or why we're stopped.
  6. Apr 5, 2021 at 1:02 PM
    #106
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    gabbo2112 likes this.
  7. Apr 5, 2021 at 1:35 PM
    #107
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
  8. Apr 5, 2021 at 1:40 PM
    #108
    atpage
    Western NY
  9. Apr 5, 2021 at 1:44 PM
    #109
    GarlicFarts
    Lil Rhody
    I have gone out with people "if you hear my horn that means I flipped over" :rofl:
    Anyway, as far as licenses and radios....
    CB - Citizen band, no need for any license, just the radio. Handhelds work, but are mediocre. Full setups are better, but other than for off road, they're relatively useless for us. Truckers use them, and usually just bitch at each other at merge points, and discuss if rest stops are open. I just did 7300 some odd miles out to LA and back - google can reroute me easily, I don't have a 53ft trailer to worry about. If I did, the CB comes in handy for road/highway closured and reroutes (IE: 10 is blocked, trucks won't fit on exit 17, take 22 and then go up and around....Tacoma fits everywhere, no worries, just follow the google). Very few people have them other than truckers nowadays, as most trails coms have gone to....
    FRS - Family radio service, these are stock radios you buy from the store and have 20 some odd channels pre-programmed in. They cannot change the antenna, and the face must only show the channel numbers. They're limited in power - they can only transmit up to a certain wattage (more on that in a second). NO LICENSE IS REQUIRED for FRS radios on the FRS bands.
    GMRS - General Mobile Radio Service, a license IS required, no test is required. It was (still is, for now) 75 bucks for 10 years from FCC. Recently, they reduced that to 50$/10 years (might be even less, can't remember). These actually use the same channels as FRS (IE: Channel 9 on FRS is Channel 9 on GMRS). A GMRS (and FRS) radio needs to be accepted by the FCC, for example, programming any old radio to transmit on the FRS/GMRS frequencies is not permitted. GMRS adds the use of repeaters, and some more power.
    https://www.buytwowayradios.com/twr-fgrqrc.html
    So, on channels 1-7, FRS and GMRS are about the same. 8-14 they are exactly the same and limited in power, and 15-22 GMRS can blow away FRS. In this range though, you also get GMRS repeaters.
    HAM - Doesn't actually stand for anything, technically it's "Amateur radio license", Ham is just the common name for it. Might be because back in the days of CW (Morse code), amateur operators (versus the pros) were "ham fisted". Whatever. This one needs a test, is (was) free, soon to be the same cost as GMRS license. You get a call sign, lots of rules, lots of power rules, etc.
    Kicker - If I, amateur radio licensed, get a radio and program frequencies, I am limited. No matter what my level of certification is though, I cannot (legally) put in, say, 467.5875 MHz frequency and broadcast on any radio OTHER THAN an FCC approved FRS or GMRS radio. That is channel 9, so either way, it'll only be 0.5W.
    SO THAT being said....
    As long as you know the FRS GMRS frequencies (somewhere on the internet I'm sure they have a list) you COULD in theory I GUESS....put those into a Baofeng UV5R or any other radio (which I GUESS you could find on Amazon). Which will TX at 8W (I believe, I might actually be wrong on that one!)
    Realistically - the FCC isn't running around the woods in the middle of NY for a bunch of idiots saying "go left", they got bigger fish to fry. "Officially", IE Off road clubs etc, have to be on the up and up for obvious legal/liability reasons.
    (I have an amateur license and I have a baofeng in my truck that I have programmed for RX only!!!!!!!!....... on the GMRS/FRS frequencies.
    TL;DR -
    Legally - use these on channels 1-14, 15+ has repeater chatter but you can still use them if you were so inclined. No license required and they'll do the trick. No fancy dancy programming needed or anything like that.
    https://www.amazon.com/Motorola-T10...keywords=FRS+radio&qid=1617655348&sr=8-4&th=1
    Brownmatthall[QUOTED] likes this.
  10. Apr 5, 2021 at 2:22 PM
    #110
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    True. These things are the 58mph in a 55 zone version of FCC illegal.
    Brownmatthall and GarlicFarts like this.
  11. Apr 5, 2021 at 4:16 PM
    #111
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Interested in the meet. Wish I could make it but it's my kids' opening day of baseball and I'm coaching them both, soooooo - hopefully next time!
  12. Apr 5, 2021 at 4:29 PM
    #112
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    You can move me to the going list I’ll be driving there Saturday morning hoping to convoy with @mabepossibly and who ever else we can pick up
  13. Apr 5, 2021 at 4:53 PM
    #113
    12taco12
    rochester NY
    2012 TX Pro
    @atpage you going friday or sat?
  14. Apr 5, 2021 at 4:53 PM
    #114
    Brownmatthall
    2016 TRD OR DCSB
    Offer still open for anyone that wants to head over together further downstate (i84>17)
  15. Apr 5, 2021 at 4:54 PM
    #115
    12taco12
    rochester NY
    2012 TX Pro
    anyone in roc area im around and going sat morning as well if ya wanted to caravan
  16. Apr 5, 2021 at 5:07 PM
    #116
    atpage
    Western NY
    Have to wait on a closer weather report. But probably Saturday morning.
    GarlicFarts likes this.
  17. Apr 5, 2021 at 6:10 PM
    #117
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    If everyone turns out this will be one of the biggest ones we've done so far! This is awesome!
    We will be driving out Saturday morning. Leaving from Waterford around 07:00. For comms we're old school, just hand held cb at the moment.
  18. Apr 5, 2021 at 6:18 PM
    #118
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    For the caravan from Albany, how about we meet at the Pilot at the top of I-88 in Rotterdam at 7:30, leave at 7:45? Google maps has BHM as 1:59 from Pilot.
    Who is meeting up?
    @mabepossibly
    @jmferg
    @adk_tacoma
    @gabbo2112
    GarlicFarts and gabbo2112 like this.
  19. Apr 5, 2021 at 6:34 PM
    #119
    gabbo2112
    New York
    2020 TRD Off Road
    I’m down to meet there will have to google where the pilot is in Rotterdam is tho, I’m coming right at ya from Greenwich can meet in Albany too
  20. Apr 5, 2021 at 6:42 PM
    #120
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    I figure it would be a central spot. No matter what part of Albany or Saratoga you are coming from it will send you down I-88.
    Get on I-88 from the Thruway. Pilot is the first exit past the toll plaza, very hard to miss.
